What type of trans fluid is best - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-24-2005, 05:04 PM   #1 (permalink)
For a 1999 4runner sr5 3.4L v6? I did search the forum, but did not find a specific answer, sorry if I missed it somewhere. I have heard that the correct solution is Dexron 3, and that toyota did not change to this T-4 solution until post 02 models of 4 runner.
I do not want any trans trouble so I want to ensure I use the correct solution. I will be using a transmission fluid machine to pull out the old stuff and put in the new, which I believe it takes about 7.6 quarts of the new fluid to completely replace the old fluid, so I will be picking up 8 quarts of whatever the right fluid is I suppose.
theryanator is offline
Old 10-25-2005, 07:51 PM   #2 (permalink)
Ok no replies as of yet, that is ok. I now have found that Dexron III replaces Dexron II so I know I need to use that solution. On another note, would anyone recommend a specific BRAND of solution? I am wondering if paying 3.50 per bottle for Valvoline that is "for cars over 75k" (I am at 140k) or if paying 2.00 per bottle for some other brand is just as good.
Thanks everyone!
Old 10-25-2005, 09:28 PM   #3 (permalink)
marko3xl3's Avatar
Send a message via AIM to marko3xl3
You can use (in increasing order of quality) Dexron III, Toyota Type-T fluid (which wasn't available back then, but is good to use) and GOOD synthetic fluid...like Mobil 1 or Amsoil. The more you pay, the longer it will last, both the fluid and your trans and the better it will function, but all of them work just fine. You can use plain 'ol Dexron III for 120k miles, but it wouldn't protect the transmission as well as $7 synthetic.
Also, when you use the BG machine to change your transmission fluid, you are gonna need 16 quarts. The transmission has a dry-fill capacity of ~12 quarts and you need 16 for the machine to work properly. It can get expensive. I just did my trans with Mobil 1 synth and it cost me an arm and a leg but I have peace of mind now and it also seems to shift better sometimes.
__________________
:Marko:
Supercharged 98 4Runner SR5 4x4 3.4L
4" Deckplate :: TrueFlow Air Intake System :: Magnaflow 18" Muffler w/ Resonator
XM Satellite Radio (Roady 2)
:: Autometer Boost Gauge :: Color Keyed Spoiler
TOYOTA|moving forward
marko3xl3 is offline
Old 10-26-2005, 07:19 AM   #4 (permalink)
My manual for my 99 4runner says it only needs about 7.6 quarts of the fluid?
Old 10-26-2005, 07:27 AM   #5 (permalink)
nrgetic99's Avatar
Transmission will shift better with a Type T. Actually, T-III or T-IV.
That transmission was designed around slightly firmer, crisper shifts than
DEXRON III will offer. To me, a shorter ship is better on the transmission as less time 'slipping' is less chance to put heat in the system. Heat and excess heat will kill a transmission quicker than a crisp shift.
I tried a DEXRON fluid in my Super Charged 99 and hated the slow shift which was especially noticeable in the 2-3 shift under full acceleration.
Additionally, the T-IV fluid has better Friction durability than the DEX III which means in effect, it maintains optimum frictional characteristics and hence optimum shifting longer.
Just my 02 cents
David
__________________
98 Limited: Taco/Tundra TRD/OME lift, diff drop, LC rims, 32" REVOS, TJM T-17, Magnaflow
93 SR5 V6 4WD *** TOTALLED **OME lift, Aisin hubs, 31x10.5 Dueller ATon 15x8 AR23's, clears, Silverstars, K&N, Dynomax, Yakima ...
03 V8 Sport. Jaos Center Protector, Landmaster Dual beams, Silverstars, RD leather interior , TRD rims/X-Terrains - gone :-(
99 SR5 "Highlander", SC'd, SAW/Downey,32's,Addco,deck plate, TRD cat back, 1.5Kw stereo ...gone , not forgotten
96 SR5 Dune... 1.5kw stereo
nrgetic99 is offline
Old 10-26-2005, 07:42 AM   #6 (permalink)
Just my 02 cents
David
Where do you acquire the T IV fluid? I did not see any at my local Autozone. I thought I had seen a service bulletin saying that my 99runner would be best if I used that solution, the T-IV. However, the dealership said to use Dexron III which replaces Dexron II which is indicated on the dipstick on my truck as the solution to use.
I really dont want to mess up my trans so I am inclined to go with a high quality Dexron III at this point as indicated by the dealers in my area, but am open to using the T-IV if I can learn more about why to use it and WHERE to get it. Is T-IV a viable safe replacement for the Dexron III? My dealerships had not even heard of it, at least in relation to what a 99runner should use.
Old 10-31-2005, 12:35 PM   #7 (permalink)
surf4runner's Avatar
anybody ever used "B&M trick shift" in a toyota auto trans? my friend wants to use it in his runner.
__________________
sarcasm noted...and appreciated
im with the banned
Quote:
Originally Posted by fustercluck View Post
I was traumatized. I had nightmares of trained attack tupperware beef-logs chasing me all night! Don't bend over, Fuster!!!!!
Quote:
Originally Posted by Lysmachia View Post
Just pile us nekkid in an engine bay and drizzle us with gear oil and watch the fun!
surf4runner is offline
Old 11-03-2005, 11:50 AM   #8 (permalink)
tomstin's Avatar
Quote:
I find that remarkable, since my 03 Highlander REQUIRES the T-IV???? The synthetics handle both the heat and the cold better. The Amsoil products have served me well.
__________________
2001 Tacoma SR5, V6 Auto, Perma-tech bed liner, Gaylord lid, Deck plate, Amsoil fluids, Hayden Trans cooler, Supercharger, Level 10 Valve Body, URD Fuel Mod, RAAMmat/Ensolite Sound Deadening
tomstin is offline
Tags
02, 1999, 4runner, 98, atf, capacity, fluid, runner, shift, synth, trans, transmission, trick, type, valvoline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
rear end fluid type? (middle of locker install look inside for type) FOCUSHERE 84-85 Trucks & 4Runners 3 10-21-2006 05:22 PM
power steering fluid type ronniedaniels 86-95 Trucks & 4Runners 4 10-01-2006 04:00 PM
what type of radiator fluid do i need? fireteacher General Vehicle Related Topics (Non Year Related) 38 09-11-2006 04:21 PM
trans fluid type? burntaco 95.5-2004 Tacomas & 96-2002 4Runners 1 05-21-2004 05:22 PM
?? changing tranny fluid + trans case fluid + diff fluid.... sage 95.5-2004 Tacomas & 96-2002 4Runners 1 06-22-2003 09:38 PM
2009 InternetBrands, Inc.
