What size nut on pitman arm?
Old 05-03-2003, 06:07 PM
GreyHawk's Avatar
What is the size of the nut on a 95 pickup 4x4 from the steering box to the pitman arm? I think it maybe 32 mm. I need to buy a socket for it.
GreyHawk is offline
Old 05-04-2003, 11:25 AM
GreyHawk's Avatar
It is a 32 mm.
GreyHawk is offline
Old 05-04-2003, 07:48 PM
jx94148's Avatar
Good to know. Does it require a deep socket? I hope to never have to mess with mine but you never know. I bet its the same on all the early IFS. Both 4Runners and trucks, probably T100s as well.
jx94148 is offline
Old 05-10-2003, 04:19 PM
GreyHawk's Avatar
Nope just a reg 32 mm socket. Now I'm having a rough time getting the pitman arm off. I've broken 2 pullers........ I'm also replacing the idler arm, another PITA. I've gotten one bolt out but the other 2 I can not break open. There I've broken 2 sockets, just got an air compressor (Had to run a 15 amp dedicated power source to the garage for it), impact gun and still can not break the 2 bolts..... Thinking of grinding the heads off and just getting new bolts.
GreyHawk is offline
I8URSVT
09-03-2015 11:42 AM
justdifferentials
Just Differentials
08-30-2015 08:42 PM
Gravel Maker
RuffStuff
08-06-2015 04:27 PM
upongame619
08-01-2015 12:12 AM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
Quick Reply: What size nut on pitman arm?
