What maintenance needs to be done? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-13-2005, 09:50 AM   #1 (permalink)
Haniblectre's Avatar
Send a message via ICQ to Haniblectre
My 99 4runner has 118k on it. I currently am running amsoil 5w-30, an the amsoil oil and air filters. I am taking it into a shop today to get the transmission flushed out and amsoil transmission fluid put in. Is there any other general maintenance things that I need to have the shop do while it's there? Maybe check the rotors/brake pads/brake fluid, and the differentials to make sure that everything is satisfactory?
__________________
1999 SR5 4runner 3.4L V6 4wd, Alpine CDA-9855 deck, 2 JL 10W3 subs, Alpine T757 amp, MB Quart 6.5" coaxials in rear doors and MB Quart 6.5" components in front doors. Grille guard and tail light guards.
Upgrade Plans: S/C, headers, exhaust, 2" suspension lift 1" body lift, 33" mtr's, trd wheels, TJM-17 front bumper, custom rear bumper w/ tire holder.
Haniblectre is offline
Old 10-13-2005, 10:04 AM   #2 (permalink)
Sponsoring Member
midiwall's Avatar
You're overdue for a timing belt (it's rated for 90k), and while you're behind the front cover, the water pump should be replaced. The parts cost is about $140, but there's about 3-4 hours of labor involved which will run you an additional $250-300 or so.
Have you ever had the front or rear diff oil changed? That should be done.
What kind of driving do you do? Is it all on-road? If not, then things like axle seals, rear bearings, etc are coming up on their due.
The BEST thing that you can do is find a buddy locally that's comfortable with wrenching and learn how to do some of this stuff on your own. For example, the labor behind checking rotors, pads, etc. will be as much as the parts cost.
Investing the equivilent of one hour of labor costs ($75ish) in an all-in-one tool set from the local auto supply place will go a LONG way. The tools won't be the best you can buy, but they'll do fine while you learn about your rig.
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 10-13-2005, 10:14 AM   #3 (permalink)
look in the maintenance section and read the first sticky
bob
Bob_98SR5 is offline
Old 10-14-2005, 10:39 AM   #4 (permalink)
Paul H.'s Avatar
Coolant change, hoses and belts replacement come to mind.
__________________
92 4Runner SR5 V6 4X4
Skyjacker Nitro shocks, Pro-Comp steering stabilizer, clear bumper lenses, lund windjammer, OME standard coils, ISR mod, inlet pipe removed, Bushwaker Fender Flares.
2002 Tacoma Prerunner V6 Xtracab. Lund Intercepter bug guard, rear glass sunshield, Bilstein shocks on rear.
2004 Honda CRV EX stock belongs to wife.
Quote:
Originally Posted by habanero View Post
I did a lot of masticating today.....and now I'm going to go do some more.
Paul H. is offline
Old 10-17-2005, 06:14 AM   #5 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Might also want to check out this very similar thread:
http://yotatech.com/showthread.php?t=69227
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
What other maintenance should I do? idealconcepts General Vehicle Related Topics (Non Year Related) 3 04-11-2007 11:29 AM
Why I do my own maintenance! ugadawg95 Off Topic Talk 22 08-24-2006 10:45 AM
Some ?'s about maintenance. READYFORTHEGRIDLOCK Maintenance & Repair Archives 7 08-26-2005 07:09 PM
2009 InternetBrands, Inc.
