| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
V6 3.0L Water pump Removal
#2 (permalink) |
It doesn't seem too hard. THe water pump is a part of this timing belt write-up.
http://www.off-road.com/toyota/tech/v6tbelt/
__________________
94 4runner SR5, V6 3VZE, 5 speed Completely rebuilt engine with Toyota parts at 147k miles Downey Coils, Aisin manual hubs, Cowl Louver mod, Hella 500 fog lights Yeah, I know, not many cool mods here |
#3 (permalink) |
Thanks for the write up guy.
#4 (permalink) |
Yeah, it's not too hard at all. Took me about 6 hours to do mine. The crank bolt is a major pain though. Once you get past that, it's easy...just a bit tedious to get the timing to line up sometimes.
If you don't have a Torque wrench that will go to 181 ftlb/torque, you can pick one up at autozone for free under thier loan a tool program. You may need a pulley puller from them too. Well, have fun! ![]() Daniel
__________________
------------------------------------------------ 1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto. 15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick Planned stuff: Pre-runner light bar with Hella 500s, small lift Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow. |
#5 (permalink) |
to break the crank bolt loose i use the engine, to tighen it back up, you have to have some sort of bar to keep the motor from spinning.
might as well do the timming belt while your in there.
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers 92 4runner, auto, V6, OME suspension, Downey headers |
#6 (permalink) | |
Quote:
![]() Yeah, I used a bar to keep the motor from spinning both to remove and to tighten the bolt. It works good.
__________________
#7 (permalink) |
I didn't have to touch the crank to do my water pump. Are you talking about replacing the timing belt while you're in there? It would be a good idea, and the only reason I'd see for having to do anything with the crank bolt.
__________________
'07 Tacoma Double Cab V6 4WD |
#8 (permalink) | |
Quote:
__________________
#9 (permalink) |
They don't have the bolt pictured in the write up from what I can see, but here is where it screws in (red arrow).
![]() I suppose if you are not going to do the timing belt, you could just take the belt off the cam sprockets and let the belt just hang there off the crank sprocket. Would save you the pain with the crank bolt, but I highly recomend changing the timing belt while you are already torn into things. Change the thermostate too. Make sure, when you are done, that all the marks line up (green lines on the crank sprocket and also check the marks on the cams). Rotate the crank 2 times by hand when you are done and recheck all marks. Well, hope that helps! Have fun all. ![]() Daniel
__________________
------------------------------------------------ 1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto. 15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick Planned stuff: Pre-runner light bar with Hella 500s, small lift Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow. Last edited by DH6twinotter; 10-28-2005 at 10:51 AM. |
#10 (permalink) | |
Quote:
__________________
#11 (permalink) |
youll see the white tick marks on the cam wheels. These line up with marks on the black sheetmetal backing plates. so yes technically you can replace the waterpump without takeing the lower crank pully off
__________________
#12 (permalink) |
Snap-on and bassinfool are right, you don't have to take the belt off the crank pulley unless you want change the belt (recommended). Also, in the picture above, it looks like they removed the power steering pump. You don't need to do that.
Here is an AutoCAD drawing I whipped up for the bar that keeps the crank from turning: ![]() Buy a peice of steel and cut a hole large enough to fit onto the crank pulley and around the little tabs sticking out. Use the end of the peice of steel sticking up (or resting on the ground) to keep the crank from turning. Put your socket (19mm I think) through the hole in the steel and onto your crank bolt and rotate with your rachet. Use your PS pulley bolts to hold the piece of steel onto the crank pulley Hope that makes sense. Kinda confusing. Have fun. ![]() Daniel
__________________
------------------------------------------------ 1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto. 15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick Planned stuff: Pre-runner light bar with Hella 500s, small lift Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow. Last edited by DH6twinotter; 10-28-2005 at 01:36 PM. |
#13 (permalink) |
(pics are of my truck) and i took the power stearing pump off because it was leaking and well, your there anyway why not. i dont think you HAVE to but every time ive done one on mine i have.
i made a bar out of angle iron for mine but just bolted to 2 bolts that were next to each other, leaving the center open for the rachet.
__________________
#14 (permalink) |
Oh, I didn't realize that was your truck.
I noticed the bar on the crank in your picture there. Looks nice! Looks a lot more like a real tool than my crappy piece of steel. Doesn't toyota (or somebody) make a tool similar to this called an SST or something? Seems like I read that somewhere. ![]() Well, have fun all. ![]() Daniel
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Fuel Pump - 1GR-FE 4.0L V6 - what's the psi rating?? | windancer4x4 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 08-15-2006 12:57 AM |
| 3.0L V6 oil pump /water pump/timing belt | t3yfg5 | The Classifieds GraveYard | 1 | 05-05-2006 06:35 AM |
| Best place to get a water pump? 3.4L V6 | vegaskurt | Maintenance & Repair Archives | 3 | 11-07-2005 09:03 PM |
| water pump removal? | Babypig | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 03-01-2004 06:53 PM |
