troubles in paradise
Old 06-12-2005, 11:41 AM
yota_in's Avatar
97' 4runner w/ 22re - - everything was going fine and i saw no signs of trouble after a little bit of driving to a friends, then i turn the runner off and when i come back out it wont start. there is no sign of the runner even trying to turn over and i get absolutley no power. it wont jump start either. i have no idea whats wrong with it, i have checked all of the fuses and the battery n spark plugs.. does anyone konw what might be wrong?? or has anyone had any similar problems? pleeease help me! i just got a new lift kit n some superswampers for it but now it wont start!! please help!!!
yota_in is offline
Old 06-12-2005, 12:06 PM
EWAYota's Avatar
have you tried taking your battery out and putting a different one in? i had a problem like that last summer with my buddy's truck. he pulled up, turned it off, i grabbed the keys and turned it over, and nothing. tried jumping it all night, nothing, not even a click. then a 5 minute drive to walmart, dropped the new battery in, and it fired right up. could be a possibility.
EWAYota is offline
Old 06-12-2005, 01:17 PM
rimpainter.com's Avatar
Another possibility is the starter contacts. Try going from ON to START --> ON to START rapidly. If it does start up, visit Roger Brown's site and do some research. He also has your fix if the contacts are the problem. www.4crawler.com
rimpainter.com is offline
Old 06-12-2005, 01:23 PM
waskillywabbit's Avatar
Check the wire to the starter solenoid. If the connector is old and bad they just fall off after a while or get a bad/no contact. If that contact is bad your rig won't do anything when you trick to start it.
waskillywabbit is offline
Old 06-27-2005, 04:49 PM
awoods's Avatar
this has happened to me on occasion too. i dont know if your runner has an alarm on it but mine has a techtronics alarm system in it with a little cpu chip looking key. i havent thoroughly figured out how it all works completely but i do know it can shut your car down. anyway this happened to me the other day and finally i just unplugged and plugged that key back in and it started right up. i dont know if you have an alarm like that or not but that seemed to be my problem
awoods is offline
Longbed 90
03-11-2019 12:38 PM
voiddweller
10-02-2015 07:47 AM
Matthew Perez
09-28-2015 05:43 PM
Boomer8404
09-17-2015 07:59 AM
128keaton
09-03-2015 05:09 PM
Quick Reply: troubles in paradise
