| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Transmission fluid change and the torque converter??
#2 (permalink) |
First off, Don't ever take your rig to the STEALERSHIP!!!
Yes, if you just drain the tranny there will be fluid left behind in the torque converter and internal lines. The only way to get all this fluid out is to flush it out. In my opinion, all you need to do is drop the Transmission pan and replace the filter and fluid. If you want to get it flushed then take it to a Good auto repair shop in your area. and save yourself a couple hundred bucks!!
__________________
1990 4Runner 4x4 3.0 Auto. Sitting on 31X10.50 Baja Claws, Aisin manual hubs, OME shocks & coils. Optima Redtop, 40 Series Flowmaster and High flow Cat |
#3 (permalink) |
You can also flush it yourself for free. It takes about 12-14 quarts for a full flush, draining and dropping the pan only gets about 1/3 of it out.
A search for tranny flushes should bring up the DIY method.
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! |
#4 (permalink) |
Excellent job on searching (saw that you brought up another post)
. I'll add that you should check out www.gadgetonline.com. He's got a procedure outlined and other nifty info. Amsoil also has an outline on their website.
__________________
#5 (permalink) | |
Quote:
__________________
:Marko: Supercharged 98 4Runner SR5 4x4 3.4L 4" Deckplate :: TrueFlow Air Intake System :: Magnaflow 18" Muffler w/ Resonator XM Satellite Radio (Roady 2) :: Autometer Boost Gauge :: Color Keyed Spoiler TOYOTA|moving forward
#6 (permalink) | |
Quote:
So if I am gathering there is a major difference between a DRAIN of trans fluid and a FLUSH of the fluid? I will check the status of the fluid when I drain it and if it looks burnt I will just go ahead and flush it. I think I will just buy 16 quarts to be safe, and I can always return the leftovers if I dont end up flushing the system. Will the trans fluid machines they have at shops FLUSH the system thouroughly? And to end my questions in this department, any recos for the best fluid for a 144k 99 runner? Thanks |
#7 (permalink) |
Be sure to clean the collection magnets while you have the pan off.
__________________
#8 (permalink) | |
Quote:
Also, synthetic is always the best. My dealer told me that if I didn't bring in synthetic they would use the new Type-T fluid and then Dexron III. Don't know how all that works, but that's what I've been told. Also, I believe the reason they are charging you $200 is because they don't wanna help their customers. They will come up all kinds of excuses about how they have to open up their machine to use customer fluid etc. etc. Now, if you want to use their own fluid it should really only cost $100-$120 for a flush. Don't know how much a drain and refill costs. Lucky me, I have a good dealership in my area (read: Capitol Toyota in San Jose, CA) and they had no problem using my own synthetic fluid. They didn't pull any BS. They always have one of their flushing machines that are spankin' clean and after they use customer fluid they just run hot water through it and bam, it's clean again. IMO, $200 is too much, i would try and find someone who cares about your needs and will do it to you for a good price with proper service.
__________________
#9 (permalink) |
[quote=marko3xl3]There is definately a great difference between DRAIN and FLUSH. Draining will marely replace 3-4 quarts of fluid from the total of 12, therefore mixing old and new fluids together. It's better than nothing but way inferior to flushing, which takes 16 quarts to replace 12 quarts of fluid.
Are you sure there is 12 quarts of tranny fluid in the truck? I don't think this is right. When we dropped the pan, we replaced 4 quarts and I don't think the torque converter has another 8 quarts in it. I think there's probably another 4 quarts max in the tc and the lines. Can someone confirm for me? |
#10 (permalink) |
There is a chain of jiffy lube like places out here and most of them have that machine. I believe they charge $49 to do the flush if you bring your own fluid. The local toyota dealer wants $130 to do it. But 16qts of synthetic is $$$
So my advice is to find a local shop if you were quoted $200. |
#11 (permalink) | |
[quote=ebelen1]
Quote:
Pan+TQ+Lines+Cooler
__________________
#12 (permalink) | |
Quote:
Dropping the pan will only change about 1/3 of the fluid so you would need repeated changes to have the same effect. Now if the fluid is not in bad shape or under severe use, then doing a flush becomes less critical (most of the time I just drain and fill, dropping the pan every 45k to clean the filter). If you are switching to a synthetic, then yes, you should also pay for a flush initially.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#13 (permalink) | |
Quote:
#14 (permalink) | |
Quote:
http://www.gadgetonline.com/TransFlush.htm So when you drain the pan you actually only do 1/5 of the fluid not 1/3 as I mentioned earlier. :pat:
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 11-04-2005 at 11:26 AM. |
#15 (permalink) | |
Quote:
Nevertheless, gadget had a bone-dry tranny and he put in 15 quarts so that has to be right. Thanks for the post. |
| Tags |
| 4runner, 96, auto, bring, change, converter, filter, fluid, flush, flushing, including, mechanic, price, replace, torque, trans, transmission |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Auto transmission, t-case and torque converter for 22re PA/MD | MtnToys | The Classifieds GraveYard | 6 | 10-19-2006 06:05 PM |
| how do you change your transmission fluid the easy way ? | yota5VZFE | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 12-19-2005 08:00 PM |
| How to complete flush and do a complete transmission fluid change. | Haniblectre | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 03-02-2005 11:31 PM |
| 3rd Gen Transmission Fluid Change | Fingers | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 12-07-2004 04:51 AM |
| transmission fluid change | mielkep | Maintenance & Repair Archives | 17 | 10-09-2004 09:04 PM |
