| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
transfer case problem?
#2 (permalink) |
Any Ideas?
#3 (permalink) |
does it have manual locking hubs on the front wheels? if so u need to lock them ,move the dial from free to engaged.
#4 (permalink) |
The truuck has ADD. Like I said, the front drive shaft won't engage, so its a problem with the T-case. It spins freely while in 4wheel with the truck stopped.
#5 (permalink) |
Is your dash light on which shows "4WD"?
__________________
1993 Toyota 4x4 PU 22RE 5 speed 30x9.5-15 |
#6 (permalink) |
Yeah the light goes on when I shift it in. I traced the leads for that light and it goes to the front diff. The 4wd light would seem to indicate that the ADD is working. I am wondering if it may be something simple before I tear out my t-case.
#7 (permalink) |
Does it have push button 4wd, like the newer automatics, if so I think there is a solenoid that switches from 2-4. I'm not an expert on autos, mines a 5 speed, not that I'm an expert on them either but I know a little more
![]() I do have a factory manual I can email to you if you want to look at that. If so send me an email address. |
#8 (permalink) |
It's a floor lever shift for 4wheel. That would be killer if you could send a scan my haynes is not very helpfull.
stephenskis@hotmail.com |
#9 (permalink) |
Check the vacuum lines for any leaks. ADD won't engage fully if there is a leak in the lines.
George
__________________
*99 Desert Dune SR5 4WD 5spd, Amsoil filter, Extended diff breathers, Deck plate mod. Bilstein Shocks, Hella 500 fog lights mounted on TJM T-15, Stubbs sliders, Type "O" Throttle body gasket, Optima Redtop, ARB Air compressor, ARB RD23 air locker, Shackle hangers, Custom catback exhaust with Magnaflow muffler. |
#10 (permalink) |
Here is the 93 FSM, it should be about the same as the 91: http://personal.utulsa.edu/~nathan-b...fsm/index.html
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 04-30-2005 at 08:23 PM. |
#11 (permalink) |
thanks man!
#12 (permalink) |
Your t-case should be the chain drive (VF1A).
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#13 (permalink) |
Thanks again for th FSM. Based on the drawings I'm guessing it's the linkage to the front drive shift fork or the fork itself. It's a seperate linkage for the hi/low so thats why it can shift into low and not 4wheel. I'll take a look tomorrow.
#14 (permalink) |
I've heard the chain drive t-cases are weaker but I've never seen a failure first hand. Let us know what you find out. Good luck.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| transfer case shifting problem | cig4059 | 86-95 Trucks & 4Runners | 5 | 02-06-2007 09:32 AM |
| Transfer case ??? | Lunnzz | 86-95 Trucks & 4Runners | 9 | 12-15-2006 01:00 PM |
| Transfer case ? | MNBOY | 86-95 Trucks & 4Runners | 3 | 01-13-2006 07:55 PM |
| What transfer case do I have? | TRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 07-21-2005 09:31 AM |
| Transfer case leaking problem... | MorphiasX | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 01-11-2005 09:13 PM |
