Tranny Problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-26-2005, 11:38 PM   #1 (permalink)
Tranny Problem
I've got an 89 V6 Auto with about 197,000 miles. It is regularly maintained and runs great. However, when I come to a stop, it seems that the tranny does not shift down right. I feel a kick when I come to a stop. It seems as if the tranny did not shift all the way back down to first gear. Also, when I take off, I feel the same kick as if someone bumped into me from the back. Fluid is good, red, and again, regularly maintained. I've had it flushed already with no avail. Are there any adjustments to this?? The tires are stock 225 75R 15's. THanks for your help.
Legacy 4Runner is offline
Old 08-27-2005, 12:45 AM   #2 (permalink)
Corbit's Avatar
Could be the shift solenoids in the tranny . Does it go into first if you manual it?
Corbit is offline
Old 08-27-2005, 08:59 AM   #3 (permalink)
tranny
corbit- yes, if i can manual it into 1st, shift into 2nd, and so on. In terms of the solenoid, what does that take to repair? A complete tear down?
Old 08-28-2005, 07:54 PM   #4 (permalink)
90
90's Avatar
Are you getting trouble codes from the trans ? Although it has been noted solenoids can go without alerting the ecu, you should see codes on the OD light in the 6x range.
Solenoid surgery is reasonably non-invasive; if you want pix, somebody here did a valve body job with Level10 and posted pix on another site .The solenoids are clearly visible...Google is your friend
__________________
"Whiskey is for drinking. Water is for fighting over."- Mark Twain
90 is offline
Old 08-29-2005, 05:08 AM   #5 (permalink)
Slowrunner's Avatar
Rear brakes (ABS)
__________________
1990 4RUNNER V6 AUTOMATIC
Slowrunner is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
tranny problem smyoder General Vehicle Related Topics (Non Year Related) 3 08-12-2008 09:01 PM
Tranny problem Tortuginator 86-95 Trucks & 4Runners 1 07-09-2007 10:01 PM
Tranny problem...? desertyota 95.5-2004 Tacomas & 96-2002 4Runners 0 04-25-2007 04:15 PM
Tranny Problem? Gladden 95.5-2004 Tacomas & 96-2002 4Runners 1 10-14-2004 09:51 AM
is my problem the tranny or something else? jchin 95.5-2004 Tacomas & 96-2002 4Runners 14 08-27-2004 04:53 PM
2009 InternetBrands, Inc.
