Tranny fluid change? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-05-2005, 11:21 PM   #1 (permalink)
fo_runner's Avatar
I have a 3rd gen 3.4 AUTO, with well over 130k on it. I think the tranny fluid has been changed once, but I doubt it.I havn't checked the fluid yet, which I will do later on. I'm thinking about flushing the whole system out and replacing it with a generic synthetic brand. Mainly DEXRON III, since T-IV is non exsistant here.
Is there anything else I should consider before I change my old tranny fluid out?
fo_runner is offline
Old 11-05-2005, 11:31 PM   #2 (permalink)
if youre not sure and youre at that mileage interval, i'd highly suggest you do the total fluid exchange.
lots to read: http://yotatech.com/search.php?searchid=1195688 get yo' self some edjumacation!
bob
Bob_98SR5 is offline
Old 11-06-2005, 01:08 PM   #3 (permalink)
fo_runner's Avatar
I just checked the tranny oil today and it didn't look cherry red, but kind of a mixture of brown and dark red. It smelled like freshly grinded metal, and the cloth i used to clean the dipstick with becoam brown.
Bad signs of tranny fluid?
Old 11-06-2005, 11:08 PM   #4 (permalink)
vegaskurt's Avatar
How does it compare to this? http://www.yotatech.com/showthread.php?t=71116
vegaskurt is offline
Old 11-07-2005, 07:34 PM   #5 (permalink)
fo_runner's Avatar
It was alittle darker than that. Slightly browner, but some visible red spots.
If I do need to flush and fill my ATF fluid, how many quarts will I need? 12 quarts of Amsoil which is roughly $165 CDN, seems too much. Is Mobil 1 ATF similar to Amsoil?
Old 11-07-2005, 08:13 PM   #6 (permalink)
marko3xl3's Avatar
Send a message via AIM to marko3xl3
16 quarts to use the dealer machine to do a flush. There was a thread about it recently if you don't believe it. The machine need the extra 4 quarts so that it would replace 99% of the fluid instead of leaving 20% of hybrid stuff in there (mix between old and new).
I got Mobil 1 (about $100 U.S for 16). It's definately similar to amsoil, good synthetic, but by numbers, amsoil wins by 5-10%. Personally, I would say that unless you plan on entering a nascar race with your truck, don't worry about the numbers and use Mobil 1. It's more readily available as well.
__________________
:Marko:
Supercharged 98 4Runner SR5 4x4 3.4L
4" Deckplate :: TrueFlow Air Intake System :: Magnaflow 18" Muffler w/ Resonator
XM Satellite Radio (Roady 2)
:: Autometer Boost Gauge :: Color Keyed Spoiler
TOYOTA|moving forward
marko3xl3 is offline
Old 11-08-2005, 01:18 AM   #7 (permalink)
If you are unsure when the fluid was changed last, I would NOT recommend at trans flush. I work in the automotive industry and have heard of various problems resulting from Tranny flushes. My service advisor says to only flush if you are gonna do it every 30,000 miles. On older trannys he says to only drain and fill, but to do it somewhat frequently.
__________________
1996 4Runner Limited TRD 2nd Gen. Supercharger, 4WD, Performance Products Exhaust, Amsoil Air Filter, Performance Products Front Lip, Clear Lights w/ All Piaas, NR White Face Gauges, Kenwood CD, MB Quart Speakers, Eclipse 10" Sub, Fosqate 400 Watt Amp, Hayden Tranny Cooler, Fox Coilovers, American Racing Baja Wheels, 285-75-16 BFG Muds
koyota93 is offline
Old 11-08-2005, 03:51 PM   #8 (permalink)
marko3xl3's Avatar
Quote:
In the 4Runner worls, you should check for the size of metal shavings on the magnetic filter and based on that decide what you are gonna do. Too many big metal shavings in the filter is a sign of failure and flushing at that point is almost immediate death.
__________________
:Marko:
Old 11-08-2005, 07:31 PM   #9 (permalink)
fo_runner's Avatar
What if I do the flush myself, how many quarts of ATF should I use then?
Old 11-09-2005, 08:20 AM   #10 (permalink)
mt_goat's Avatar
How are you planning to flush it? Here is the best info I've found yet on tranny flushing: http://www.gadgetonline.com/TransFlush.htm
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Tranny fluid change question Wife's 4runner General Vehicle Related Topics (Non Year Related) 10 01-04-2007 05:32 PM
Does overfillin the tranny w/ fluid hurt the tranny? CILO 86-95 Trucks & 4Runners 4 02-02-2006 10:44 AM
change tranny fluid or not at 112k miles? madmaniac 95.5-2004 Tacomas & 96-2002 4Runners 16 03-18-2004 11:16 AM
fluid change rollandfayssoux Maintenance & Repair Archives 2 12-16-2003 03:29 PM
?? changing tranny fluid + trans case fluid + diff fluid.... sage 95.5-2004 Tacomas & 96-2002 4Runners 1 06-22-2003 09:38 PM
2009 InternetBrands, Inc.
