YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-09-2005, 01:16 PM   #1 (permalink)
4x4taco's Avatar
Send a message via AIM to 4x4taco
Question tranny/diff/t-case oil
I've never changed the oil in my tranny (5 spd), diffs or t-case and it's very overdue. Since this would be the first change, can/should I go to synthetic or stick with regular oil? Either way, what brands do you guys reccomend? Amisol seems to be good stuff but I want something I can go to a shop and buy. Are the oils for those specific or do all 3 parts take the same stuff? Thanks!
__________________
'00 Tacoma TRD
TJM T-15 / OME 882 & 1" BL / "custom" intake / 33x10.5 BFG A/Ts on Teflon Chambers / Demello sliders
4x4taco is offline
Sponsored Links
To remove this ad, register today!
Old 10-09-2005, 02:19 PM   #2 (permalink)
4Crawler's Avatar
Your Owner's Manual will have the grades, weights and qty. of oil to use. Here is what my '85 O/M listed:
http://www.4crawler.com/4x4/4R_TechInfo.shtml#Fluids
and what I fill mine with:
http://www.4crawler.com/4x4/index.sh...ntheticGearOil
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-09-2005, 02:30 PM   #3 (permalink)
yes, look in your owner's manual in the specifications section (back of OM)
just buy mobil 1 products if you dont want amsoil stuff. if you decide on amsoil, let me konw because I (as well as many others) on the forum are independent dealers.
take a look at my writeup on the subject too: http://www.4runners.org/articles/difftsf
bob
Bob_98SR5 is offline
Old 10-09-2005, 02:34 PM   #4 (permalink)
bob200587's Avatar
I went with the cheap stuff, Coastal, I'm pretty sure on mine it was all the same weights.
__________________
87 4runner 4x4 SR5 22RE
ARB Bull Bar,
31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Mellowtone Muffler
AISIN Manual Hubs, Marlin Crawler Sliders
181XXX miles
92 Ford Ranger 4x2 4.0L 4 speed auto
FOR SALE
Needs Transmission And Head gasket work.
Contact me for Details.
Facebook
"An Open Mind is Like a Fortress with its Gates Unbarred and Ungaurded."
"There are two kinds of people in this world that go around beardless: boys and women, and I am neither one."
-Greek saying
bob200587 is offline
Old 10-09-2005, 06:51 PM   #5 (permalink)
AZBlackTacoma's Avatar
Out of curiosity, how many miles does your 00 have on it?
__________________
www.tacomaforums.com
AZBlackTacoma is offline
Old 10-09-2005, 07:30 PM   #6 (permalink)
TACOMANATOR's Avatar
Quote:
Time for yours too?
__________________
2000 Taco SR5 V6 5speed TRD
Airaid MIT
Vortex muffler
DEI 2-way
Extang Tuff Tonno III
TACOMANATOR is offline
Old 10-09-2005, 10:29 PM   #7 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
im to lazy to change mine i think its never been changed
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is online now
Old 10-10-2005, 09:12 AM   #8 (permalink)
4x4taco's Avatar
Um...it has about 95k...I know, I know, I'm a horrible person for waiting this long! I think I'm just lazy also and would rather go drive it. But I have treated it well for those 95k miles. I try to drive really smooth on the street to minimize wear.
Bob, do you know what size washers/crush washers you need so I can get them before I start? Is there a problem with reusing the originals, I do that with my engine oil with no problems.
And about my main concern...it sounds as if I can switch to sythetic with no problems?
__________________
'00 Tacoma TRD
4x4taco is offline
Old 10-10-2005, 09:29 AM   #9 (permalink)
4Crawler's Avatar
I've never replaced the washers on my tranny and axle plugs except when I went to the new hex socket style plugs. Never had any leaking problems and some of those plus are/were nearly 20 years old. You can get new washers from the dealer, the drain and fill plugs are 18mm OD.
I finally had to replace the original washer on my oil pan drain plug last time I changed oil. I think it may have been original.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-10-2005, 12:36 PM   #10 (permalink)
4x4taco's Avatar
I agree with you Roger, replacing them might be one of those things they say you should do, but it's really not that necessary unless they are obviously worn out. It just seems to create more of a hastle when you go to change the fluids.
__________________
'00 Tacoma TRD
4x4taco is offline
Old 10-10-2005, 05:33 PM   #11 (permalink)
CynicX's Avatar
Send a message via AIM to CynicX
my wrx had a crush washer on the oil drain plug. I didnt replace it once and it leaked cause of the oil pressure. Some people get lucky but for something so cheap and easy to do it seemed silly not too. A crush washer is designed to be crushed once to form a tight seal around two illregular things, therefore its designed to only work once. But I'm sure it will probably be ok, but why risk it?
Of course it leaked under the pressure of the oil pump. Which the transfer case/diff/manual transmission dont have.
__________________
06 Subaru WRX
CynicX is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Hypoid tranny/xfr case oil, or no? Keggo 86-95 Trucks & 4Runners 1 08-27-2006 06:54 PM
Diff/transfer case/tranny gear lube capacities? (Amsoil synthetic switch) CoedNaked 86-95 Trucks & 4Runners 1 07-14-2006 07:41 AM
?? changing tranny fluid + trans case fluid + diff fluid.... sage 95.5-2004 Tacomas & 96-2002 4Runners 1 06-22-2003 09:38 PM
diff and T case oil change toyotaguy97 Maintenance & Repair Archives 3 05-31-2003 03:11 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
