timing belt....anything else? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-23-2005, 05:11 AM   #1 (permalink)
ohio4runner4x4's Avatar
Question timing belt....anything else?
I sent TRDparts4u.com a request for parts to do a timing belt, water pump and themostat job on my 2000 4Runner. They sent back and said that I need the following:
13568-69095 BELT, TIM 33.12 1
16100-69398-83 WATER PUM 88.84 1
90916-03075 THERMOSTA 11.03 1
16325-62010 GASKET, W 3.36 1
90311-38051 SEAL, TYP 6.41 2
90311-40022 SEAL, TYP 4.63 1
00295-00103 FIPG OIL 8.98 1
I want to replace everything with new...don't want to re-use any gaskets, seals etc.....Are there any other parts, gaskets or seals that you guys might know about that aren't listed above? Also...is there anything else I should be replacing while I'm in there this far? I need the 4Runner back together the same day and don't want to find out that there is something else I need in the middle of the project!
Thanks guys!
Todd
ohio4runner4x4 is offline
Old 04-23-2005, 06:25 AM   #2 (permalink)
111db's Avatar
Send a message via MSN to 111db
Todd, sorry I can't really help since I haven't done my timing belt yet. But am interested in seeing what the replies are here, since its on my agenda here in the next month or so and I'm getting a parts list together.
Also I wanted to send a shout out since I grew up in Valley City and have a lot of friends in Medina. Go Bucks!
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 04-23-2005, 07:01 AM   #3 (permalink)
rimpainter.com's Avatar
You might want to do the drive belts since they will be off too. Kinda depends on how they look and their mileage.
rimpainter.com is offline
Old 04-23-2005, 07:07 AM   #4 (permalink)
111db's Avatar
What exactly are these items?
__________________
Jon
111db is offline
Old 04-23-2005, 10:13 AM   #5 (permalink)
Not sure....I just copied and pasted what they sent me....
Old 04-23-2005, 10:34 AM   #6 (permalink)
dont know all the part numbers...but i replaced mine in my 3.0 and i got all the gaskets for the timing cover along with the idler and tensioner. not sure how a 3.4 is..but if it is anything similar then i'd replace the idler and tensioner just to be safe. and yeh...replace the drive belts too. they say replace the cam seals too but i never could get my cam sprockets off but they looked good for now.
callmej75 is offline
Old 04-23-2005, 10:45 AM   #7 (permalink)
Staff
Yoda's Avatar
FIPG = form in place gasket (like silicone)
I use the grey ultra seal silicone sealant (oxy sensor safe, japanese vehicle aproved)
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 04-23-2005, 07:24 PM   #8 (permalink)
I would definitely replace the timing belt tensioner. They are a gas type tensioner, (similar to the gas struts on the rear hatch) and can lose pressure over time.
It's a simple job, the factory timing belt has all the marks on it that have to be lined up correctly, Ie: left cam, right cam, crank.
The biggest problem I had, was I had to unbolt the A/C compressor to access one bolt for the tensioner, but even that isn't difficult. Good luck.
02SE is offline
Old 04-23-2005, 07:31 PM   #9 (permalink)
1 last thing...getting the harmonic balancer off. put ya a breaker bar on there with a socket and have someone tap the ignition switch to break it loose...worked for me
Old 04-25-2005, 08:09 AM   #10 (permalink)
Sponsoring Vendor
Strap22's Avatar
The Tensioner Part#13540-62021, Idler #13505-62070, Idler #13503-62040 are some other parts depending on milage and condition you may want to replace. If you have any other questions please contact us at:www.info@trdparts4u.com
__________________
Phil
Toyota & TRD Parts Wholesale
www.FJCruiserOffroad.com
www.trdparts4u.com
www.toyotapartsales.com
Authorized ARB/OldManEmu Dealer
Authorized OASIS Air Deflators Dealer
Strap22 is offline
Old 04-27-2005, 10:24 AM   #11 (permalink)
I just did mine on my 00 Tacoma, 3.4 liter. Set aside around 5 hours to get it all done. I didn't change the tensioner or idler, but you might want to order the special Blue Point tool that spreads the tensioner so you can get the belt on. I belive it's YA9370, around $60 shipped. It makes life a lot easier. Don't forget to put new "red" toyota cooland in it.
ACPlayer is offline
Old 04-27-2005, 10:35 AM   #12 (permalink)
My99's Avatar
Send a message via AIM to My99
Quote:
Why?...
__________________
Kyle H
Current Yota: 86 4Runner - Daily Beater
My99 is offline
Old 04-27-2005, 12:51 PM   #13 (permalink)
The "red" toyota coolant is the long life coolant and is the one recommended by the manufacturer.
ACPlayer is offline
Old 04-27-2005, 12:53 PM   #14 (permalink)
My99's Avatar
Oh, I thought there might be a real reason.
__________________
Kyle H
My99 is offline
Old 04-27-2005, 01:05 PM   #15 (permalink)
I had a lab break down the contents of "red" toyota coolant and it came back as follows:
50% ketchup
25% carbonated water
25% Kool Aid, Tropical Punch flavor
I guess you can probably make some at home for cheap. Let me know how it runs in your truck.
ACPlayer is offline
Old 07-11-2005, 05:06 AM   #16 (permalink)
111db's Avatar
Save yourself $60 and just remove the tensioner instead of buying the tool.
Quote:
Actually you can get to the aft tensioner bolt directly underneath it with a 12mm socket on a wobble extension. I had to remove two 10mm bolts for the little wire bundle that runs across the top front of the oil pan, and slide the wire bundle slightly to the drivers side to see the bolt head. Its there, a little tricky, but definitely quicker than taking off the a/c compressor.
__________________
Jon
111db is offline
Old 07-11-2005, 06:49 AM   #17 (permalink)
Reldnew's Avatar
50% ketchup
Hilarious!
Actually, it used to be sugar free Kool-Aid "Very Berry" but the FDA pulled the red dye #3.
__________________
Reldnew
91 4Runner-Very Used
but Very Usable!
Reldnew is offline
Old 07-11-2005, 06:19 PM   #18 (permalink)
I am doing some service on my 4Runner too (92K). So far i have (engine-wise): waterpump, timing belt, sp plugs and wires, engine belts, thermostat, and radiator hoses. I read this topic but i dont think the question was answered, do i need to buy any gaskets or seals that aren't FPIG? Also, anyother parts that i should add? I dont know how many miles i should acquire before doing the tensioner replacement. Help is appreciated, Thanks.
__________________
1999 Imperial Jade Mica Toyota 4runner Limited 4wd
-Jensen Flip Down Monitor
-Blaupunkt DVD/VCD/CD/Mp3
-Bed-Liner coated skidplates
FlzRider is offline
Old 07-12-2005, 08:50 AM   #19 (permalink)
Do the belt tensioner and idler bearing with timing belt replacement.
__________________
2001 4Runner 3.4V-6 SR5 4x4 | 16x,xxx miles | Stock auto grenaded planetary gear mod | IPT Built A340F stripped Planetary gear mod | Tranny #3 good luck | Stubbs SKO sliders | Bud Built front skid | Trail Carnage belly skid | Rockware rear bumper | Goodyear MT/Rs | | OME 882/890 | Trekmasters | Detroit Locker rear | Truetrac up front | 4.88s
2008 FJC TT SE 6 SPEED
naksukow is offline
Old 07-12-2005, 02:52 PM   #20 (permalink)
Thanks for the tip, any info on seals and gaskets?
__________________
FlzRider is offline
Old 07-12-2005, 03:14 PM   #21 (permalink)
Don't know off hand but I can check the online manuals for you. I am actually pulling my tranny today and bought a 1 day pass on http://techinfo.toyota.com/
__________________
naksukow is offline
Old 07-12-2005, 06:25 PM   #22 (permalink)
Looks like there is a 1 gasket for the upper cover and 1 for the lower cover and 1 for the water pump. If you want I will email a pic.
__________________
naksukow is offline
Old 07-13-2005, 11:10 AM   #23 (permalink)
I would appreciate it if you could send the picture to gto2004@yahoo.com
Thanks alot!
__________________
FlzRider is offline
Old 07-13-2005, 05:28 PM   #24 (permalink)
Quote:
Thanks alot!
Sorry bro...you responded past my 24hr window...I can send it about a week.
__________________
naksukow is offline
Old 07-13-2005, 07:42 PM   #25 (permalink)
It's alright, just as long as i know that there are 3 gaskets that i must buy. I want to do all the work in one day, not wait for parts.
Thanks either way....
__________________
FlzRider is offline
Tags
0029500103, 2001, 4runner, 9031138051, 98, balancer, belt, fj40, frunner, harmonic, remove, replacing, tensioner, timing, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Timing belt Sambo General Vehicle Related Topics (Non Year Related) 0 01-22-2007 01:00 PM
Timing Belt Toy7 95.5-2004 Tacomas & 96-2002 4Runners 6 03-12-2006 01:16 PM
engine belt/timing belt replacement question gomezza Maintenance & Repair Archives 2 04-11-2005 03:48 PM
timing belt please help!!! 95red4runner 95.5-2004 Tacomas & 96-2002 4Runners 7 07-17-2004 07:21 PM
Timing Belt getchellad 95.5-2004 Tacomas & 96-2002 4Runners 11 12-07-2002 06:27 PM
2009 InternetBrands, Inc.
