testing compression - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-11-2005, 10:01 AM   #1 (permalink)
Jared Ajlouny's Avatar
testing compression
my runner is leaking oil (not to the point where it gets on the ground, but it makes the engine look messy). all i want to do is test the compression cause if the compression is good im just going to replace the head gasket and oil pan gasket and call it a day..... i know on my jet ski to test it you take both plugs out (2 cylinder) and put the guage in one and hold the throttle open and start cranking away..... is that what i do for the runner?! i know 2 stroke engines like the back of my hand, but i have never delt with a 4 stroke........
__________________
98 taco, 4x4, TRD, SR5, extended cab, v6. 3" on 32s (dd)
86 4runner 5spd SAS soon to be geared and locked! (CRAWLER)
2000 yamaha superjet setup for freestyle, cause thats just how i roll!
Jared Ajlouny is offline
Old 11-11-2005, 10:09 AM   #2 (permalink)
surf4runner's Avatar
if doing all cylinders, i recommend removing all plugs first. otherwise no diff betweeen doing it on a 2 or 4 stroke.
__________________
sarcasm noted...and appreciated
im with the banned
Quote:
Originally Posted by fustercluck View Post
I was traumatized. I had nightmares of trained attack tupperware beef-logs chasing me all night! Don't bend over, Fuster!!!!!
Quote:
Originally Posted by Lysmachia View Post
Just pile us nekkid in an engine bay and drizzle us with gear oil and watch the fun!
surf4runner is offline
Old 11-11-2005, 02:59 PM   #3 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Pull the EFI fuse when doing it so the vehicle does not start.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 11-11-2005, 10:29 PM   #4 (permalink)
i dont think it will start without spark plugs....
__________________
Old 11-11-2005, 10:55 PM   #5 (permalink)
marko3xl3's Avatar
Send a message via AIM to marko3xl3
Quote:
You never know...better safe than sorry!
__________________
:Marko:
Supercharged 98 4Runner SR5 4x4 3.4L
4" Deckplate :: TrueFlow Air Intake System :: Magnaflow 18" Muffler w/ Resonator
XM Satellite Radio (Roady 2)
:: Autometer Boost Gauge :: Color Keyed Spoiler
TOYOTA|moving forward
marko3xl3 is offline
Old 11-12-2005, 07:29 AM   #6 (permalink)
Just pulling the plugs will not stop the ignition from firing and you may fry the ignition (maybe not, but I wouldn't chance it).
__________________
- Jamie
Old 11-12-2005, 09:10 AM   #7 (permalink)
YotaJunky's Avatar
Quote:
How about just pulling the wire from the ignition coil for those that use a coil, cap rotor etc..?
Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD
YotaJunky is offline
Old 11-12-2005, 12:55 PM   #8 (permalink)
DudeBud's Avatar
Send a message via AIM to DudeBud Send a message via MSN to DudeBud
Quote:
Troy
much easyer to pull the efi fuse so the injectors don't squirt fuel. thats just what i do
__________________
Dan
95 4runner 3vze A/T
84 4runner sr5 Ford 302
T-18 4spd yota t-case
yota front and rear both open
37X13.00 boggers
88 4runner 22re 5spd
DudeBud is offline
Old 11-13-2005, 06:41 AM   #9 (permalink)
YotaJunky's Avatar
Here's a good article. I think I'll test mine out now.
http://www.geocities.com/SiliconValley/2072/carcomp.htm
Troy
__________________
Old 11-13-2005, 06:58 AM   #10 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Probably might be a good idea to do a compression test and a leakdown...mine leaked oil, smoked like a fat indian chief and in general ran crapy...compression test was all fine...leakdown wasn't so great, but okay...but I just rebuilt the whole engine anyway...all new OEM parts and it runs like a new squirrel again.
waskillywabbit is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
No Compression!!!!????!!! jriebe 86-95 Trucks & 4Runners 9 05-29-2007 06:03 PM
compression testing procedure? spacoli 86-95 Trucks & 4Runners 12 01-08-2007 08:58 AM
compression Q Y2Krunner 95.5-2004 Tacomas & 96-2002 4Runners 9 05-27-2003 08:35 PM
2009 InternetBrands, Inc.
