| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
sway bar
__________________
1996 4Runner SR5 V6, stuff... 2007 Dodge Ram 2500 4x4 QuadCab Cummins Turbo Diesel |
#2 (permalink) |
Factory sway bar is fine, or I imagine there are stiffer bars available aftermarket, Sway-A-Way, Addco, etc.
Or, just get some new end-links the proper length for the lift you'll be putting on: http://www.4crawler.com/4x4/CheapTri...#DisconnectsV2
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
Super Moderator-Sponsoring Member
Staff
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#4 (permalink) |
Staff
the other thing you can do its yank them out completely, i've ran NO sway bars for a while with out a problem, including smashing through mountain curvie roads.... you'll get better flex with out them too.
__________________
94 4runenr: all the good stuff....... 89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs. 81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s pacific-crawlers.com For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :) |
#5 (permalink) |
yeah no sway bars isn't too bad if you're off the pavement a good bit. I live in the mountains and it's actually kind of fun driving on the winding mountain roads with them off, but on the highway at 65+ it gets a little tricky. You really need to keep a good hand on the wheel and hope that you dont have to make any emergency maneuvers.
#6 (permalink) | |
Quote:
#7 (permalink) |
I didn't even think about needing more length on the sway bar link with the added spring height. Am I correct in thinking that the sway bar end should be level with the lower control arm?
__________________
#8 (permalink) |
You bet, generally you want the ends of the sway bar to be sitting horizontal at rest. Why? Drive hard around a turn and one side of the bar is pushed up, one side pulls up on the opposite side of the suspension. If you start out horizontal on the end, the up and down angles are the same, so you get equal forces on the bar and suspension. If, for example you lifted the suspension and left the bar hanging down at some angle and went around the same corner, the one side would push the end of the bar up, closer to horizontal. The other side would be pulled down farther by the opposing suspension arm. With the near horizontal end, it would have the full leverage effect on the sway bar since the cosine of 90 degrees is 1.0. However the end of the bar that is down at some angle, would have a lesser amount of leverage, reduced by the cosine of it's angle. So this imbalance would result in the bar needing to be twisted farther to resist the cornering force, more twist = more lean in the vehicle or a less efficient sway bar. For example, assume the bar was down at 15 degrees due to the lift and in a turn it was twisted 15 up and down. That would leave the up side at 0 degrees (i.e. horizontal) and the down side down at 30 degrees. At a 30 degree angle the efective length of the end of the bar is now only 86.6% what is was when level (i.e. cos(30)=0.866). So that side can only provide 86% of the roll resistance as it could when level.
A good lift kit should have available a properly sized end-link replacement for the sway bars. Same thing with an LSPV bracket for the rear axle.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 10-08-2005 at 10:18 PM. |
#9 (permalink) |
Thanks for the info!! I'll keep it all in mind when I order everything!
__________________
#10 (permalink) | |
Staff
Quote:
__________________
#11 (permalink) | |
Quote:
#12 (permalink) |
I added a sketch:
![]() and a description on the web page: http://www.4crawler.com/4x4/CheapTri...#DisconnectsV2
__________________
#13 (permalink) |
Staff
thanks for reminding why i hated statics so much.... lol jk, it wasnt that bad of a class
__________________
#14 (permalink) | |
Quote:
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
| Tags |
| 1985, 4runner, aftermarket, bar, sway, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| sway bar | tampabayota | General Vehicle Related Topics (Non Year Related) | 23 | 07-12-2007 11:58 PM |
| sway Bar End Links - stabilizer bar link - please clarify | wellyman | 86-95 Trucks & 4Runners | 9 | 01-23-2006 08:54 AM |
| Sway Bar | van7559 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-11-2005 09:06 PM |
| 2nd gen IFS sway front sway bar, is it really important? | Ilovemountains | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 07-29-2004 07:20 AM |
