| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
surging idle with a/c on?
__________________
1991 Toyota Pickup 22RE 2wd 1/2 ton 5spd; Genuine Toyota Quality Last edited by 91RN81; 09-14-2005 at 12:00 PM. |
#2 (permalink) |
the AC idle up valve needs to be adjusted. check out
www.4crawler.com for the causes and corrections. or you can PM him.I woulld try yo explain right not now but I'm not sre how long I will have power.......
__________________
Will WabFab Off-Road, LLC Toyota 4x4 Parts and Custom Fabrication updated website with lots of new products 87 runner with every bolt on available |
#3 (permalink) |
I dont see any information about this on 4crawler.com??
__________________
1991 Toyota Pickup 22RE 2wd 1/2 ton 5spd; Genuine Toyota Quality |
#4 (permalink) |
Sorry about that. I had sporatic power yesterday.
The AC idle up valve is located on the intake plenum (around the middle) and can be adjusted. The problem, it seems is that youre idle with the ac on is at or around 1200 rpm. That is the magic # to turn the AC compressor on. if it falls below that it will kick off. And the reverse will turn it on, causing it to surge. The answer to this is to turn the Idle valve up some and keep it from going below 1200 RPM. PS I'm not sure which way to turn it to make it change. Good luck and let me know how it turns out.Feel free to PM me if needed.
__________________
#5 (permalink) |
You have the A/C fast idle set too high and this is causing you to hit the ECU's fuel cut RPM when you apply the brakes, see this recent Toyota Trails Truck Tech column Q&A:
http://www.4crawler.com/4x4/TLCA_Tru...ech.04.09.html Note: I can exactly duplicate this on my '85 if I crank up the A/C fast idle setting too high. If I turn the fast idle down the problem goes away.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 09-16-2005 at 08:39 AM. |
#6 (permalink) |
Thanks Roger
__________________
#7 (permalink) |
Clean your throttle body. Then try it. Clean the living crap out of it.
James
__________________
New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569 Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/ |
| Tags |
| 11, 1991, 22re, ac, cut, genpower, idle, ompressor, parts, pickup, rpm, surge, surging, toyota, truck |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Idle surging | islandrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 01-28-2009 01:21 PM |
| surging idle fixed... | highway | 86-95 Trucks & 4Runners | 1 | 02-21-2007 07:51 PM |
| surging idle | teamafx | 86-95 Trucks & 4Runners | 12 | 02-16-2007 01:59 AM |
| Idle surging...please help | jjcobra99 | 86-95 Trucks & 4Runners | 17 | 02-27-2006 06:24 PM |
| Surging idle 22re | Tiger Paw | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 01-12-2005 07:14 PM |
