signal wont turn off with turn
Old 06-09-2005, 04:24 PM
jimbo74's Avatar
ok so whats wrong with my truck? my turn signal doesnt turn off when i turn.... it does sometimes, but most times it jsut stays on until i manually turn it off
jimbo74 is offline
Old 06-09-2005, 05:10 PM
eric-the-red's Avatar
There's usually a little plastic ratchet thingy in the switch that turns them off, sounds like yours is worn out. Don't know if you can fix it without getting a new switch.
eric-the-red is offline
Old 06-09-2005, 07:38 PM
jimbo74's Avatar
so its actually part of the switch? the part that is connected to the signal stalk? i beleive its the multi switch or something right?
jimbo74 is offline
Old 06-09-2005, 07:39 PM
DudeBud's Avatar
yeah its called the turn signal cam
DudeBud is offline
Old 06-09-2005, 08:17 PM
jimbo74's Avatar
so this cam is indeed part of the switch and not part of the column correct?
if i replace the switch i should be good to go....
jimbo74 is offline
Old 06-09-2005, 08:24 PM
dibble9012's Avatar
Just something to think about, still probably replacing the switch would fix it. Today I was fooling around in my dash, and had to go somewhere. I was driving around without the center console on (without the hazards switch connected) and I did not have any blinkers at all. Pertaining to your problem, my turn signal stalk did not go back into the neutral position after I turned ( its a habit of mine to use the turn signal, by the second turn I made, I realized that the stalk had not moved back). I would believe that the two problems go hand in hand, since you have signals, my 'problem' might mean nothing. phew, that was a long post, lol, I need to get off of here, its 12.30
dibble9012 is offline
Old 06-09-2005, 08:32 PM
jimbo74's Avatar
signals work fine... and so do my hazards
one day i was driving... felt a pop. then then the signal wouldnt turn itself off. then for a few days felt an extra clunking i nthe steering wheel... then felt back to normal except that the signal didnt turn off.....
jimbo74 is offline
Old 06-10-2005, 06:57 AM
4Crawler's Avatar
Pull the steering wheel and check the cam and where it hits the switch. Likely the piece on the cam that hits the lever on the switch and/or the lever on the switch might have broken off. The cam just lifts off, so would be the easiest to replace.
4Crawler is offline
ghostmoney
01-28-2018 11:42 AM
Shoua
13
05-22-2016 05:19 AM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
PopsDad1
07-30-2015 02:21 PM
Quick Reply: signal wont turn off with turn
