Should the engine stall out when the idle adjustment screw is completely closed? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-25-2005, 05:38 AM   #1 (permalink)
YotaJunky's Avatar
Talking Should the engine stall out when the idle adjustment screw is completely closed?
I'm still dealing with a rough idle and I've now moved on to inspecting the air valve operation by fully screwing in the idle speed adjustment screw.
The FSM says that when the engine is cold (below 176 F) and the idle adjustment screw is fully screwed into the TB, the engine rpm should drop. It did not say that the engine should stall out.
The FSM also says that when the engine is warm and the idle adjusting screw is fully in, the engine rpm should drop below the idle speed stop (I don't understand this statement). It did not say however, that the engine should stall out.
I've noticed that irregardless of whether the engine is either cold or warm, and the idle adjustment screw is fully in, the engine stalls out. I've cleaned the TB, the screw, and correctly adjusted the TPS. I've got no codes.
I have a TB with a coolant hose that feeds in from one side of the TB and then another that comes out the other side. I've read from another post that the changing temperature of the coolant varies the size of an orifice inside the TB which in turn affects the air valve operation.
Any suggestions would be appreciated.
Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD
YotaJunky is offline
Old 10-25-2005, 04:48 PM   #2 (permalink)
YotaJunky's Avatar
bump...
__________________
Old 10-25-2005, 05:22 PM   #3 (permalink)
superjoe83's Avatar
Send a message via AIM to superjoe83
mine stalls if i turn it all the way in, but only if i do it fast, if i turn it in very slowly i can get it to idle with the screw all the way in but the idle is about 300-400 rpm
__________________
- Joe
1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks
1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs
superjoe83 is offline
Old 10-25-2005, 05:42 PM   #4 (permalink)
YotaJunky's Avatar
Quote:
Mine will stall out regardless of how fast or slow I turn it in. I'm wondering if this is a clue to my rough idle.
Anyone else out there try this test? Apparently, it's a test for the air valve.
Troy
__________________
Tags
2005, 22re, 4runner, 96, acura, adjustment, afm, idle, rough, screw, stall, stalls, tl, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Where is idle speed adjustment screw located? jaysonbraid30 Newbie Tech Section 4 03-23-2007 09:57 PM
Idle screw way out/up? helidriver General Vehicle Related Topics (Non Year Related) 1 09-07-2006 08:45 PM
idle adjustment, afm adjustment, & timing questions CILO 86-95 Trucks & 4Runners 1 02-17-2006 09:05 AM
Low idle followed by stall JEDI87 95.5-2004 Tacomas & 96-2002 4Runners 3 07-12-2004 08:25 PM
Big Screw on throttle body. Idle Adjustment? FireMan 95.5-2004 Tacomas & 96-2002 4Runners 1 05-18-2004 06:20 AM
2009 InternetBrands, Inc.
