| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD |
#2 (permalink) |
NO.
Having just done a ton of research to fix My cold start injector I know a thing or two about this First off the Cold Start Injector is GROUND -Switched from the Cold start injector time switch. the Positive end of the CSI Is attached to the starter. When the Time switch senses its "COLD" it closes and completes the ground loop. But being the fact that the CSI is drawing power from the starter the CSI ONLY Fires when the engine is being turned over. Hope that helps. Sounds like the Idle up screw adjustment or the coolent sensor beside the Cold Start Injector Sensor (if its a 22RE) Last edited by 4Hummer; 10-25-2005 at 11:36 AM. |
#3 (permalink) | |
Quote:
Thanks for the reply. Troy
__________________
#4 (permalink) | |
Quote:
That is correct. and it only fires while the engine is being turned over (Or the starter in engaged) |
#5 (permalink) |
Thanks Michael. I just checked the resistance specs for both the CSI time switch and the coolant temperature sensor. Both are within spec.
Troy
__________________
#6 (permalink) |
No Problem. Hope you figure the problem out.
#7 (permalink) | |
Quote:
Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD Last edited by YotaJunky; 10-27-2005 at 01:44 PM. |
| Tags |
| 22r, cold, injector, resistance, start, switch, time, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cold Start Injector | 4x4countrygirl | 86-95 Trucks & 4Runners | 14 | 02-16-2007 05:34 PM |
| cold start injector | ELD | 86-95 Trucks & 4Runners | 9 | 01-07-2007 11:32 PM |
| i need a cold start injector | 89macrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 07-07-2005 06:48 PM |
| Cold Start Injector? | 86 TurboSR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 07-22-2004 07:34 AM |
| cold start injector? | grafix43 | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 02-19-2004 08:27 PM |
