Rotor/hub
Nope, you don't need to knock out the studs. You need to pull off the grease cap on the hub, then take off the hub, then take off the rotor from the hub. I'd get a repair manual for specks but it's pretty straight forward.
Backside of the hub, have to pull the whole assembly off to get to them so it's also a good time to repack the wheel bearings. 6 of 'em back there, an impact wrench is handy for removing them.
I had no trouble removing the bolts connecting the hub and rotor, I had difficulty removing the hub from the rotor afterwards. The haynes manual said to knock out the studs (but this is wrong, leave them in!)
I used a shop press to push the hub out of the old rotor. I doubt that there's a better way to do it without damaging the hub. That thing was really wedged in there!
Here's a pic of the parts you need to remove to get the hub and rotor off the truck.
The inner part of the hub fits tightly into the main opening in the rotor. Depending on how long your hub and rotor have been together, the rust and whatnot will make it difficult to separate the two. I was so disappointed after removing all the bolts connecting the hub and rotor to find that the two were still stuck together, I mean really stuck together!
I'll try and find a pic to show you.
scoostraw
7
04-22-2013 03:38 PM
My99
06-13-2007 03:30 PM
