Re-torque what...-- service Question (yes i searched)
Old 04-03-2005, 06:25 PM
gomezza's Avatar
Hello all... I did a search and could not find my answer. I just finished my service and the only 2 things i did not do are... 1. "retorque propeller shaft" 2. Re-torque drive shaft flange bolts. Anyone know what they are torqued to and where these bolts are!? Thanks guys!!!
H-
gomezza is offline
Old 04-03-2005, 06:36 PM
Bigblock's Avatar
there are 4 bolts in each end of the drive shaft.tighten them as tight as you can get them and tighten them some more!Mine come loose regular!
Bigblock is offline
Old 04-03-2005, 07:09 PM
gomezza's Avatar
you're kidding right? There has to be a reason they say "torque"... just like you can damage ur rotors by over torquing the lug nuts! Anyone know the specs to the bolts?
gomezza is offline
Old 04-03-2005, 07:33 PM
Guest
frankenrunner's Avatar
it's 54 ft. lbs on 4x4's &/or 56 ft. lbs. on the 3VZ-E engined drive shafts.
-f-
frankenrunner is offline
Old 04-03-2005, 07:36 PM
Ironmike4x4's Avatar
Specs
I am assuming you are talking about the torque specs on your '99 Runner so here goes.
Prop shaft at 54 ft.lbs.
Flange bolts at 54 ft. lbs.
This is according to Alldata.com so if it's wrong I assume no responsiblity. I personally think the Propshaft bold is supposed to be more but at work I use whatever the specs says for liability reasons.
Ironmike4x4 is offline
Old 04-03-2005, 08:29 PM
gomezza's Avatar
have a lot of you noticed the bolts on your 4runner's in need of torquing?
gomezza is offline
Old 04-03-2005, 08:43 PM
Nic
Nic's Avatar
When I removed my driveshaft a while back, I was going to re-torque them back to spec. But, its was so darn difficult (if not impossible) to get a torque wrench on the bolts, I just gave up and tightened them the old fashioned way.
Nic is offline
Old 04-04-2005, 09:29 AM
miket223's Avatar
Hah, torque. That's funny. Every tech including me in the Toyota shop I work at uses the 1/2" impact until it stops spinning torque setting.
miket223 is offline
Old 04-04-2005, 05:58 PM
gomezza's Avatar
hehe I dunno if thats a good thing for its life span... Sure hope my dealer didnt do that!
gomezza is offline
colasurdo
05-14-2022 07:21 AM
stock87yota
07-31-2015 10:08 AM
TURBOrunnerNM
07-22-2015 11:01 AM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
Quick Reply: Re-torque what...-- service Question (yes i searched)
