| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Question on transmission fluid
#2 (permalink) |
If you go down a few threads you will find some good info on ATF fluid. You will need about 16 quarts to flush typically. And if synthetic is $2 more than the dexron then you have to ask your self. Is another $32 gonna kill you? And is the extra $32 gonna be worth it when you can drive an extra year or so on the fluid?
Just a thought... Im saving right now to get the Amsoil or Redline ATF. Figure do it once and have the enjoyment of knowing that it was done right. |
#3 (permalink) |
I appreciate the input. I would rather run a cheaper cost fluid and change yearly. I know that Amsoil products are great but don't like their extended change intervals. Just my opinion.
The SuperTech brand is much cheaper than the $2 a quart difference. It's about $6 a gallon vs $6 a quart for Mobil 1. I'm not disagreeing that the synthetic is not better. It is!! But I have other things to spend money on and really don't want to invest so much for a fluid change. |
#4 (permalink) |
O'Relly has the Mobil 1 ATF for $4.99/qt if that makes a difference. I just bought 20 qts last week. If you don't run synthetic I'd recommend a cooler for sure, unless you plan on selling the vehicle soon.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#5 (permalink) | |
Quote:
I doubt seriously it has true genuine DEXRON and MERCON approvals. If it does, it will have a genuine license number on the label or inkjetted onto the bottle. Wll mart will drive the price into the ground for potential suppliers so do not expect a lot of R&D, spproval programs or expensive fluids under a Wall Mart brand. Whille it is true that a major company may blend the fluid, it is NOT the same as the branded fluid. Your choice but as I work in the oil Industry I can tell you, oil is the biggest bargain in auto's right now as no matter how much it costs to develop. produce or make to a consistent quality, competitive pressure means it is still waay undepriced, for the most part. David
__________________
98 Limited: Taco/Tundra TRD/OME lift, diff drop, LC rims, 32" REVOS, TJM T-17, Magnaflow 93 SR5 V6 4WD *** TOTALLED **OME lift, Aisin hubs, 31x10.5 Dueller ATon 15x8 AR23's, clears, Silverstars, K&N, Dynomax, Yakima ... 03 V8 Sport. Jaos Center Protector, Landmaster Dual beams, Silverstars, RD leather interior , TRD rims/X-Terrains - gone :-( 99 SR5 "Highlander", SC'd, SAW/Downey,32's,Addco,deck plate, TRD cat back, 1.5Kw stereo ...gone , not forgotten 96 SR5 Dune... 1.5kw stereo |
| Tags |
| 2003, atf, change, dexron, fluid, mobil, recommended, super, supertech, t100, tech, toyota, transmission, tundra, walmart |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Transmission Fluid question | mich34 | General Vehicle Related Topics (Non Year Related) | 7 | 11-06-2006 10:00 AM |
| Transmission Fluid | Ironmike4x4 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 01-09-2005 01:22 PM |
| transmission fluid question | backfrog | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 08-30-2004 03:36 PM |
| Toyota transmission fluid question | Pitbull | Maintenance & Repair Archives | 2 | 05-02-2004 11:37 AM |
| Transmission fluid | lebeau | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 06-22-2003 04:25 PM |
