| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
puff of blue smoke on startup?!
__________________
1991 Toyota Pickup 22RE 2wd 1/2 ton 5spd; Genuine Toyota Quality |
#2 (permalink) |
That's often the hallmark of an engine that's got worn valve seals. When the engine's shut off, the oil runs down the valves, gets past the valve seals, enters the combustion chamber, very slowly during the engine shutdown period. And then when you re-start it you see a little puff of blue smoke coming out the exhaust until you run it for a minute or two to clear it. So changing the valve seals conceivably could address that problem.
__________________
1990 4Runner 4x4 3.0 Auto. Sitting on 31X10.50 Baja Claws, Aisin manual hubs, OME shocks & coils. Optima Redtop, 40 Series Flowmaster and High flow Cat |
#3 (permalink) |
It is probably valve stem seals. I had to do this on my rig a year or 2 ago. Not really a hard job, but you will need to replace the head gasket and all while you are there.
__________________
Will WabFab Off-Road, LLC Toyota 4x4 Parts and Custom Fabrication updated website with lots of new products 87 runner with every bolt on available |
#4 (permalink) |
i've valve spring and seal out without taking the cam out and doing a head gasket, but i wouldn't recommend it
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
| Tags |
| 3rz, avalon, black, blue, engine, exhaust, noise, normal, puff, puffs, smoke, start, starting, startup, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Puff of smoke at start up? | FOCUSHERE | 86-95 Trucks & 4Runners | 11 | 05-28-2007 11:07 PM |
| noise at start up, the slight puff of smoke | jrock | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 03-07-2007 06:16 PM |
| puff of blue smoke when started 4th gen v8 | mud | 03+ 4Runner/GX470, & 05+ Tacomas | 10 | 01-06-2005 02:49 AM |
| puff of smoke | mp101v | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 05-29-2004 01:13 AM |
| Black smoke on startup | oaklander | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-02-2004 09:58 AM |
