| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
ps pump belt install issues
#2 (permalink) |
Well, if it was correct when you took it off, then you forgot a spacer or something. Did you have any leftover parts???
__________________
98 4runner sr5 33"s and locked with the usual suspects
#3 (permalink) |
dont have any left over parts
FSM doesnt show any washers of any sort spacing the pulley from the pump it just seems incorrect to me, and id like to hear from some mechanics with more experience on the 3vz |
#4 (permalink) |
wowza. got me stumped. I'm doing belts this weekend....i'll be careful!
btw, i'm doing belts on a 3.4l, so I'm no help.... a
__________________
#5 (permalink) |
good luck w/ that man. hopefully your engine isnt a single rusted block like mine is
#6 (permalink) |
anyone have any ideas? im not sure where to go from here
#7 (permalink) |
All I can think of is check you put the pulleys on the right way. It's been a while since I did my timing belt but I seem to remember some of the pulleys have a front and a back, ie the groove is not centered.
You'll definitely want to correct it before driving much, the belt won't last long like that. |
#8 (permalink) |
Sounds like you might have the pully on backwards, probably has a "backspacing" on it that doesn't allow you to re-install it either way. Look for a spacer/washer that you might have missed as well.
__________________
-David '98 4Runner: SAW/OME lift, TJM bumper, Warn M8000 winch, Hayden tranny cooler, Trail Carnage front and belly skid plates, PIAA fogs, Rock lights, 33" MT's on Tech1 Rockcrawler rims, Lars sway bar discos, Sonoran bumpstops and rear bumper, RB 1" body lift, Daystar front bumpstops '73 FJ40: 327 SBC, York, Dual Batteries, custom tire carrier, Corbeau Baja SS bucket seats, Bestop top. TLCA#14428 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| PS Pump Problems | blainelukens | 86-95 Trucks & 4Runners | 8 | 12-23-2005 06:16 PM |
| ps pump info | 4rnr | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 10-11-2005 08:36 PM |
| Ok to drive without PS belt? | Joyota | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 05-27-2005 06:52 PM |
| Timing Belt and Water Pump Install?? | ravencr | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 09-22-2004 11:38 AM |
| 3.0: how to remove PS pulley from pump? | hellas | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-06-2004 12:38 PM |
