| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Power steering whine Please help!!
#2 (permalink) |
Did you get all the air out of the system. It takes a while. In the manual there is a method to getting the air out of the system, and making sure you have enough fluid. The only time my PS pump whined is when I didn't have enough fluid. Even now with 37" tires, I don't hear any complaining from the PS pump.
#3 (permalink) |
I use the bleeding instructions here:
- http://howeperformance.com/bleedinginst.html And likely you have ABS brakes and the ABS actuator is powered off of the power steering pump via lines off of the steering box.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
OK I'll try that, I thought I bleed the system good with the tires off the ground but I didnt do it this way. It looks like I didnt have the right fluid either, so I'll flush that out to. Thanks guys
#5 (permalink) |
For an all-Toyota system, ATF is the proper fluid.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| No power steering...but i want it. | joegee1773 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 07-08-2008 06:33 AM |
| Power Steering | Yodatruck | 84-85 Trucks & 4Runners | 1 | 03-19-2007 09:07 PM |
| Power steering gone | iruny4wd | 86-95 Trucks & 4Runners | 8 | 10-20-2006 05:32 PM |
| Power Steering? | slowyota | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 05-19-2004 10:57 AM |
| Power Steering Help | Denk | Maintenance & Repair Archives | 5 | 12-18-2003 08:27 AM |
