pcv valve ?
pcv valve ?
OK stupid question, where the heck is the pcv valve on a 95 4runner with 3.0L V-6. I can't find the thing. truck is using a little bit of oil and would like to rule out the pcv valve.
if you look at the passenger side valve cover under all those hoses you should see a rubber hose connected directly to the vavle cover itself. if you take off that hose you should see the pcv valve.
p.s. i tried to find a pic for you but couldn't locate one....sorry
LotOMiles
09-14-2015 11:45 PM
