P0121 - Throttle Pedal Switch Position Sensor - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 05-13-2005, 07:47 AM   #1
Andrey's Avatar
Last night my "check engine" light came one. Running through OBD-II diagnostics it came up with the following code:
P0121 - Throttle Pedal Sensor Switch "A" Circuit Range/Performance.
Honestly, I'm not even exactly sure where to look. Has someone run into similar issue or is there a place where I can adjust the throttle pedal cable position?
Andrey is offline
Old 05-13-2005, 12:27 PM   #2
boogyman's Avatar
Talking
You need to replace the throttle position sensor.. it's on the back of the throttle body.. costs about $80 at the dealership. unfortunately, cleaning it doesn't really help. I had to replace mine at about 60k
boogyman is offline
Old 05-14-2005, 06:58 AM   #3
Andrey's Avatar
Quote:
Is it difficult to replace? When I went to the dealership (had to balance tires), they quoted me over $950 to replace throttle sensor and something else. The guy recommended not to do it though since he wasn't 100% sure if that'll fix the problem.
Can I get in touch with you later on to ask for more details? I'd rather pay $80 and do it myself.
Thanks,
-- Andrey
Andrey is offline
Old 05-14-2005, 04:39 PM   #4
Tps
I had the same error, but was able to adjust mine with a feeler gauge. It wasn't that difficult, and after I reset the ECU, the code was gone. Just my $.02
Wade is offline
Old 05-14-2005, 08:13 PM   #5
Andrey's Avatar
Quote:
If you don't mind me asking, what's the filler gauge?
Thanks,
-- Andrey
Andrey is offline
94 pickup 22re sluggish bogging idle issues montanatruck 86-95 Trucks & 4Runners 14 04-21-2016 05:52 PM
Please help! smthwsn357 86-95 Trucks & 4Runners 7 04-11-2016 06:22 AM
94 pickup front diff issues and bushings Steven.m.paulk 86-95 Trucks & 4Runners (Build-Up Section) 3 07-24-2015 02:44 PM
96 3.4, very high idle no vacuum leaks I can find greenbuggy 3.4 Swaps 4 07-23-2015 12:51 PM
ENGINE TROUBLE 3vze please help :( smiley52 86-95 Trucks & 4Runners 8 07-11-2015 06:16 AM
Tags
check, circuit, engine, p0121, pedal, pos, position, problem, rangeperformance, replace, sensor, sensorswitch, switch, throttle, throttlepetal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
