| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
new ignition
__________________
92 4runner 4wd lifted dented |
#2 (permalink) |
Do you have an immobilizer in your truck? If not, rather than swapping out a new ignition and locks, consider having an immobilzer installed in your rig. The keys are useless without the immobilizer, and you'll also have peace of mind knowing that your rig is more protected from being stolen by hot wiring, or being driven away with keys. Did you have house keys attached to the truck keys when they were stolen? If you did, do your insurance papers in your rig have your address on them?
Just my 2 cents. Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD |
#3 (permalink) |
an immobalizer? is that the box iv seen under dashes with a computer chip key deal?
it was just my truck keys...
__________________
#4 (permalink) | |
Quote:
Good Luck!! Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD Last edited by YotaJunky; 09-01-2005 at 01:40 PM. |
#5 (permalink) |
Guest
Just have it rekeyed and use your alarm.
What you're seeing under the dash sounds like the the alarm module, but with the alarm "armed", I don't thhink that it would start even with the key because of the built-in starter kill switch. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ignition Switch | alwayssearchin | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 10-18-2006 06:23 PM |
| ignition problems | halza | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-19-2004 10:35 PM |
| Ignition systems | Praufet | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 02-14-2004 08:19 AM |
| Ignition Key | PutzRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 10-10-2003 12:56 PM |
| Ignition | oly884 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-11-2003 09:21 PM |
