| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
nasty knock
__________________
<===i miss that one Mine: 1991 Landcruiser 2in OME lift 33in BFG A/T's The girl's: 2001 4runner 3in Revtek, 3in body lift 35in MT Baja Claws Marlin sliders TJM front bumper |
#2 (permalink) |
Guest
Are you sure that it is coming from the "top" on the passenger ["left side(facing truck)"] side? As this is a common occurrence for the bottom driver's side, i.e., rod bearing.
If so, then I would have to say that it is the lifter and it needs to be reshimmed and/or tightened, both of which you can "search" here for info on. |
#3 (permalink) |
yeah, im possitive its coming form up there, thanks for the advice
__________________
#4 (permalink) |
they aint no hydraulic lifter in no 3.0!
#5 (permalink) |
Guest
Nah, there's not. But if you point in the right direction, they can usually sort it out for themselves, 3yotys.
#6 (permalink) |
you sure there arent hydraulic lifters? when i was trying to figure it out before i came here i was told it could be a collapsed hydraulic lifter...by a friend who happens to be a mechanic at a local toyota dealership
__________________
<===i miss that one Mine: 1991 Landcruiser 2in OME lift 33in BFG A/T's The girl's: 2001 4runner 3in Revtek, 3in body lift 35in MT Baja Claws Marlin sliders TJM front bumper Last edited by 90runnner; 07-04-2005 at 02:56 PM. |
#7 (permalink) |
Guest
The valve lifter, or hydraulic lifter (although it's operation is purely mechanical), or even camshaft follower, is basically a little cup that sits atop the valve, with a shim of varying thicknesses on top of it that acts as a spacer for the cam's lobe to ride on.
Normally the lifter itself does'nt "collapse", instead, the shim becomes worn and needs to be replaced with a new one of proper thickness, which is determined with a feeler gauge and some plasti-guage. It is also common for a spring to have "collapsed" or broken, but your problem is probally just that the shims need to be adjusted, a "scheduled maintenance" item suggested to be performed every 60,000 mis., or every 2 yrs., whichever comes first, which will definitely cause a "loud knocking" at the top of your engine. Just a little clarification to avoid confusion, so ask your "mechanic...friend" about this and let's know what he comes up with.
#8 (permalink) |
alright, thanks alot man
__________________
#9 (permalink) |
Guest
No prob, and good luck with what you find out.
Reshimming is the easiest and cheapest route, something you can do yourself, whereas a valve job would start to get a bit more involved and costly as it is common practice to do them all if you have to do one... so best wishes.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Nasty Vibration | 95SASMudRunner | 86-95 Trucks & 4Runners | 21 | 04-05-2006 05:15 AM |
| Hub noise (nasty!) | lftd_86_yota | 86-95 Trucks & 4Runners | 2 | 01-26-2006 04:08 PM |
| Knock, knock from the power steering pump! | FSRBIKER | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 12-30-2004 07:23 PM |
| knock knock? whos there? tranny? | joshik | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 03-02-2004 09:24 PM |
| knock knock, whats wrong under there?? | GoudyMan | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 01-27-2004 01:18 PM |
