Mixing Trans fluid
Mixing Trans fluid
Hey to all, asked a question reference Transmission fluid changing and learned a lot. the question I now have is, If I don't want or trust the "jiffy lubes" and I don't want to go to the "stealorship" can I do a drain and fill and mix synthetic into the existing ATF? will they mix? and if so will there be an improvement in trans life? thanks in advance. EDH
Originally Posted by Tacoma Dude
I did some research on this later and a couple people had said that they are compatible and you shouldn't run into any problems...
Follow these steps and go most of it out. http://www.amsoil.com/faqs/faq8.htm
