| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Guest
Posts: n/a
manual tranny fill plug...
#2 (permalink) |
If a socket head plug, usually 10mm. Stock plug should be a hex head, near the backup light switch. Forget the size off-hand, maybe 14 or 17mm.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
Guest
Posts: n/a
thanks roger, your the man. I tried a 3/8" allen wrench, and it would grab, but wanted to strip it, so you think a 14mm is close to it?
#4 (permalink) |
As I said, if it is a socket head plug, then 10mm allen (and 10mm is a tad larger than 3/8"), if hex head (like a bolt), then 14 or 17mm, whatever fits.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 11-19-2005 at 12:15 PM. |
#5 (permalink) | |
Quote:
10mm allen = 0.394" while a 3/8" allen = 0.375" .....I wouldn't risk it
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 11-19-2005 at 01:50 PM. |
#6 (permalink) |
Manual trannys have fluid?
If so, is it supposed to be changed at some interval?
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#7 (permalink) | |
Quote:
You can check here for intervals: http://smg.toyotapartsandservice.com/index.php
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#8 (permalink) |
its a 10mm allen head...... if you strip it out.... you can get a new one @ the toyota dealer really cheap... i have the part # listed in my truck buildup in my signature
#9 (permalink) |
#90341-18021 drain/fill plugs
#12157-10010 alluminum crush washers im stealing this picture from marlin crawler for illustrative purposes... they als osell them too, if you wnat to go that route
#10 (permalink) | |
Quote:
Of course there would be lubrication in there - I guess by "fluid" he means gear oil?
__________________
#11 (permalink) |
Guest
Posts: n/a
Well that was a PITA!!
I think I got more oil on the driveway than in the tranny Before I could read any replies, I went ahead and figured if the 3/8 almost fit, 10mm it is, and picked one up. I will be buying a plug from the dealer and drilling and tapping a nipple onto it to aid in the fluid transfer next time.. I figure run a 1/2" OD hose from the nipple/plug to the gear oil and let it drain... I plan on sawing a notch in the threads to both vent the tranny, and allow fluid to seep out when its full. for the guy who didnt know about the tranny fluid, it 75w-90, GL-4 or 5 , about 4 qts |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Transfer case fill plug part #? | CBDenver | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 03-14-2007 06:21 PM |
| Rear diff fill plug rounded off | Crux | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 01-17-2007 07:49 PM |
| Marlin Drain/Fill Plug | jimbo74 | Maintenance & Repair Archives | 19 | 05-26-2005 03:44 PM |
| Rear differential fill plug | Nathan Buchanan | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 09-23-2004 06:17 PM |
| front diff fill plug | metal22lica | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 12-23-2002 04:35 PM |
