leaking from rear??? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-19-2005, 10:38 AM   #1 (permalink)
Send a message via AIM to Localmotion
Before I get started, i DID do a search. I replaced my axle seal a couple of months ago. When i was changing my tires, i realized that there was something leaking (maybe leaking, could not find the source) from both rear tires. Now the thing is, could it just be the old stuff soaked in the brake pads? or is it new stuff. I changed my right rear axle seal but not my left. Any thoughts?
Localmotion is offline
Old 09-19-2005, 11:02 AM   #2 (permalink)
ASU4runner's Avatar
Send a message via AIM to ASU4runner
Possibly the rear wheel cylinder in the drum brakes. Mine went bad and it leaked all over the wheels.
__________________
'99 4runner Limited 4x4 w/ E-Locker
'96 4runner Limited 4x4 SOLD
SE4RJ - Pics
ASU4runner is offline
Old 09-19-2005, 11:04 AM   #3 (permalink)
X-AWDriver's Avatar
Both my rear axle seals went bad and my rear brake pads were soaked and I had them replaced when the seals were done and I bet the other seal is bad too and the side you replaced is the old stuff that collected.
__________________
'99 4Runner Highlander 4wd
E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs
Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub
X-AWDriver is offline
Old 09-19-2005, 11:13 AM   #4 (permalink)
SOB. This sucks! I replaced both wheel cylinders and they are not leaking. I took the drum off and poked the seals and nothing came out. I really hope the other one isnt leaking (in denial)
Old 09-19-2005, 07:13 PM   #5 (permalink)
4Crawler's Avatar
Check your diff breather. If it gets clogged, the hot air inside the axle can't escape and that can push gear oil out past the oil seals. Also, did you replace both seals on the one side or just the "easy" one?
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-19-2005, 07:37 PM   #6 (permalink)
Quote:
I replaced the inner and outer seals on only the Right side. I checked the diff breather and everything works ok. Do you think that the hose length has anything to do with it? Mine is kind of long. (probaby a stupid question)
Old 09-19-2005, 07:43 PM   #7 (permalink)
4Crawler's Avatar
On the hose length, the important thing is that the hose runs upward all the way from the axle to the end. You want to avoid at all costs any "dips" in the breather hose as it runs away from the axle. Why? The hot air and oil mist that comes out of the vent can/will condense in the hose and is there are any dips in the line, the oil can pool there and block off the hose. It happened to me when I used to have my rear axle vent line running up to tee into the front vent line. Gear oil is pretty thick stuff, gets thicker the colder it gets. When mine plugged, I had two axle seals and the pinion seal go out until I found the problem. It took a fairly good puff on the vent hose to blow air through it. After re-routing the line to the rear, I've had no problems since.
http://www.4crawler.com/4x4/CheapTri...html#Breathers
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-19-2005, 07:46 PM   #8 (permalink)
wow that is some great info!! Ill have to redo mine stuff tmw. Am i already SOL or if i just re run my lines ill be ok? My line runs parallel to the ground for about a foot or so. Thanks again!!!
Old 09-19-2005, 07:53 PM   #9 (permalink)
4Crawler's Avatar
Fix the lines, or at least see if they are plugged. If so and the leaking stops, you are set (the pressure was forcing the oil out). If the line is open or the leaking does not stop, then the seals are bad.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rear Diff Leaking... hatda02 86-95 Trucks & 4Runners 16 03-28-2007 07:25 PM
Leaking rear door Tacoma Dude 95.5-2004 Tacomas & 96-2002 4Runners 0 02-11-2005 05:09 PM
Leaking Rear Differential corvettelvr73 95.5-2004 Tacomas & 96-2002 4Runners 8 12-27-2004 12:23 AM
Leaking rear axel seals, rear bearing slop TahoeEd 95.5-2004 Tacomas & 96-2002 4Runners 0 12-15-2004 09:53 PM
My rear diff is leaking Airedog 95.5-2004 Tacomas & 96-2002 4Runners 3 09-12-2004 08:26 PM
2009 InternetBrands, Inc.
