key or ignittion problem..cant tell which.. but cant turn key
Old 06-27-2005, 10:14 AM
sabre's Avatar
My factory key wont go in all the way most of time. I have to give it a nice shove to get it to go in fully. Sometimes it goes right in but then wont turn. Its getting annoying and worse every time I try it. I dont think its the ignition. I think it may be the key getting twisted or something. Anyone have this problem in the past? solutions?
sabre is offline
Old 06-27-2005, 10:31 AM
Guest
94x4's Avatar
There are several different posts about "ignition switch" problems, so if you try the "search" feature, I'm sure that you'll come up with more possible fixes and causes than you ever thought possible, one of which is bound to cover your problem.
If not, the only thing that I can suggest would be to squirt some carbon (likepencil) into the ignition to loosen it up, if that be thw case.
Good luck.
94x4 is offline
Old 06-27-2005, 11:04 AM
Beartracker's Avatar
Your key may be to wore down to drop the tumblers. Also check for burrs on the key or it may be about to break. Have a new one made and see what happens. Mike
Beartracker is offline
Old 06-27-2005, 11:28 AM
sabre's Avatar
Im going to get my second key and keyless entry that my wife keeps in her car and try that. she doesnt need the key as much as she just needs the keyless to get in my truck and get stuff out. thanks
sabre is offline
gary4runner
09-24-2015 12:53 AM
JHalcyonM
08-04-2015 01:19 PM
mluz013
08-02-2015 05:00 AM
TDonkey
07-26-2015 10:14 AM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: key or ignittion problem..cant tell which.. but cant turn key
