| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
intermittent stumbling 3.0
__________________
Semper Fi, Alfred '91 4Runner SR5 4wd 3.0 V6 '10 Scion Xb |
#2 (permalink) |
Probably throttle position sensor. I have the same problem...then it stopped. Then the truck sat a week and the problem is much worse.
Assuming you've never swapped out the fuel filter, go ahead and change it. Maybe you'll get lucky and that'll cure it, but I doubt it. Usually a plugged FF will cause cut-outs at speed but will run fine at idle. You've got the fluctuating idle thing goin'.
__________________
'99 4Runner SR5 4WD, 5-SPEED. Abzug's vehicle for urban expeditions, navigating flash floods and debris flows (try 12-15 inches of rain in one week). It always gets her home. '95 4Runner LIMITED 4WD, 5-SPEED, over a quarter million on the original 3vze & headgaskets. TRD heavy duty clutch, TRD heavy duty flywheel, OME 900 springs and shocks. This old gal has gotten me out into the field, and back for 8 years, never failed to start or gotten stuck. |
#3 (permalink) |
check to make sure that the ignitor wire's contacts aren't fouled. Next check the TPS sensor. Check the wires going to the TPS sensor as well. While you are at it, change the SP wires too....though I doubt those are the culprit. FF could be it buuuut mine was fine until 198000 when I swapped it out...
__________________
3vze, 4x4, sr5, 90, auto, LSD 2x dB Drag World Finalist 2003 Nopi Nat. Street B champ 2004 SBN Street C champ 2004 SBN Advncd NW Champ 2004 Former WR Holder in NW. SPL: 159.8db @ 42hz In loving memory of Jamie Riggs 5/15/85 - 10/8/04 |
#4 (permalink) |
ha....man i went through this aggravation for over 6 months. It did get worse and would stumble all the time. Never really found the culprit but this was my long list.
Cleaned TB and checked IACV New PCV valve New Vacuum lines New fuel filter Ran Seafoam through it a few times New K&N Filter Cleaned Gas Tank New tune up New filter with 3 vacuum lines going onto it (screws into the side of the plenum) New EGR valve New Temp sensor New cold start time injector switch New AFM New timing belt and tensioners New throttle body hose New thermostat Cleaned Intake plenum I think that is it...but I also think my timing played a big role in it. Put a timing light on it just to double check. |
#5 (permalink) |
Ok...I may have found the problem.
I went to change the cap/rotor and found plastic and some metal shavings. I can see where the platic piece came from but not the metal. Also, it looks like some copper wire has come undone. It looks like the thin wire you would see in coil of some kind. Does a replacement distributor come with a cap/rotor? If so, I'll skip installing the cap/rotor and keep the truck down one more day. I've never replaced a distributor. Anyone have a good write-up? All I know is you need to align it to TDC....right?
__________________
#6 (permalink) |
to answer my own question...the distributor doesn't come w/the cap/rotor. Here are some prices:
- dealer - $500 - Napa - $300 - Advanced Auto - $200 => problem is the one I bought from them didn't fit. I'm going to try Napa. I hate having to keep going back to exchange parts! I usually buy OEM, but I can't see spending $500 for one part on an engine that has 320K on it.
__________________
#7 (permalink) |
try a wrecking yard for parts. If it's got 320k, why spend more than you need to?
Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD |
#8 (permalink) |
I got one from Napa...it looked OEM compared to AAP and the price was less than $200 with a AAA discount and core. I think I was miss quoted before.
It was running great for a couple of day, but then the idle started running too low. I adjusted the idle up and it runs fine, but I think there is another problem somewhere. No other problems so I'm happy.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| stumbling!! i don't know what to do | Toyota D | 86-95 Trucks & 4Runners | 12 | 03-27-2007 05:09 PM |
| Stumbling? | ShortyzKustomz | 86-95 Trucks & 4Runners | 5 | 03-22-2007 01:10 PM |
| Stumbling Runner | TS86 | 95.5-2004 Tacomas & 96-2002 4Runners | 27 | 01-30-2006 07:05 PM |
| engine stumbling | yotaluver | General Vehicle Related Topics (Non Year Related) | 15 | 10-19-2005 05:16 PM |
| Stumbling on acceleration? | FARMAWL | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 08-16-2005 05:10 PM |
