I Need Diagnosis Help: Ignition? Starter? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-04-2004, 03:25 PM   #1 (permalink)
My vehicle: 99 4runner SR5 V6. Miles 78000 (original owner). West Coast LA.
History: About 5K miles ago, I did some preventative maintenance to replace a leaking water pump and changed the timing belt also. Battery replaced and the same time.
Problem: Over the last month, I had problems starting in the morning. When I turn the ignition, sometimes it took two or three tries to turn over and start. When it did not start, it was not a lazy start; there was no sound. It was like it didn't make contact.
Last night, I started it and it made a loud whining noise. When I tried to turn the ignition off, it still kept running. I had to disconnect the ground from the battery for it to turn off.
Diagnosis? I'm not a mechanic, but I thinking the starter needs to be replaced. I'd like some educated guesses before I take it in.
Hhinojosa@yahoo.com
hhinojosa is offline
Old 09-04-2004, 04:10 PM   #2 (permalink)
Send a message via Yahoo to humanoid
It's definitely the starter. Mine did the whining noise as well and had to replace the whole thing. Should look at replacing the starter contacts as well since you'll have the starter off anyway. Welcome to the board, BTW! You'll find this board with a lot of helpful folk without all the needless flaming. Post some pics of your rig of ya got 'em too!
__________________
'99 Taco PreRunner V6 3.4L
humanoid is offline
Old 09-04-2004, 06:23 PM   #3 (permalink)
kevin444's Avatar
Send a message via AIM to kevin444
Im in the so cali area.
I just replaced my starter about 3 weeks ago. I went to wondries toyota and the starters there was frickin expensive like $280. Go with pepboys or replace the starters.
- kevin
__________________
02 4runner conversion complete!
kevin444 is offline
Old 11-11-2004, 06:11 PM   #4 (permalink)
Did mine 2wks ago. 160 at cheker auto. it would click(kick out the gear) but wouldnt turn the gear. 2wks before that it did the same thing and when I had it tested it was fine. I came to this conclusion depending on how old and how many miles you have on your rig, might as well replace the problem and not try to patch it, you'll just do it twice in the long run.
ALEKATNM is offline
Old 11-22-2004, 03:24 PM   #5 (permalink)
Jay
Send a message via ICQ to Jay
The original posters problem is due to worn starter contacts. This is a well known symptom. In his case, the starter solenoids plunger had become stuck to the contacts, which left his starter running until he disconnected the battery.
__________________
Jay
98 X-Cab Tacoma
3.4L Manual Trans. | TRD Fender Flares | Weld Wheels w/ 31 x 10.5's
Jason Larsen
Master Diagnostic Technician - Beaverton Toyota (Portland, Oregon)
Wendsday - Saturday by appointment only.
(503)626-7200 (ask for me by name)
Jay is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Starter Problem or Ignition Switch Problem? highplainsdrifter 95.5-2004 Tacomas & 96-2002 4Runners 0 11-12-2006 05:14 PM
dealer installed alarm ignition starter cutoff problems KyleT 95.5-2004 Tacomas & 96-2002 4Runners 6 02-21-2006 10:33 AM
Starter/Ignition Problem 90 4Runner jm47 86-95 Trucks & 4Runners 5 02-07-2006 08:23 PM
Remote Starter...Ignition Override tarheelrunner 95.5-2004 Tacomas & 96-2002 4Runners 23 01-08-2005 09:01 AM
How much $ for a diagnosis? HELP!! AgRunner06 95.5-2004 Tacomas & 96-2002 4Runners 5 02-14-2003 05:22 PM
2009 InternetBrands, Inc.
