Sign in using an external account
| Maintenance & Repair Archives Note: This section will be merged in with the other tech areas soon, and is now closed |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
how important is the bvsv ?
__________________
1988 Toyota 4x4 V6 |
#2 (permalink) |
Personal
Sales Rating: (0)
is that the valve on a coolant passage? if its the same on i'm thinking of on the supra engine i installed, i bypassed it completely and it affected nothing but then again i removed the charcoal canister entirely due to a fuell cell install instead of the factory gas tank.
if you bypass the valve the tank will be "functioning" all the time instead of just when the motor is hot
__________________
Jeremy, 94 4Runner Turbo Leaf Spring SAS front - Coilover 4link rear (starts December) / Supra Swap My Truck is featured on Supracharged.com - Home of the original Supra swap and Forum One of two things will happen, I will die, or the truck will be finished. I'm not sure which will be first. |
#3 (permalink) |
Personal
Sales Rating: (2)
Sounds like you may have either some different connections or something hooked up incorrectly. The black cannister is the charcoal filter for the evap system. On my '85 it is directly connected to the "P" port on the TB (P -> Purge). The BVSV is part of the EGR system, passes TB vacuum to the EGR modulator, but only once the engine/coolant warms up sufficiently (i.e. it blocks EGR operation when the engine is cold).
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad - YotaTech discount code Gettin'Off 4WD Club |
#4 (permalink) |
Personal
Sales Rating: (0)
listen to him, he knows more than i do
__________________
#5 (permalink) |
Personal
Sales Rating: (0)
[OP]
I think that might control the EGR on the 22r but on the 3vze its goes from the canister to the valve then to the throttle body, heres a link to what I am talking bout. http://personal.utulsa.edu/~nathan-b...74layoutan.pdf
in that picture they call it a tvv but in my chilton manual for a 88 3.0 v6 they call it bvsv. same ลลลล, different smell
__________________
1988 Toyota 4x4 V6 Last edited by justanother4x4; 06-06-2005 at 08:38 AM. |
#6 (permalink) |
Personal
Sales Rating: (0)
$51 for that part from Boulder Toyota. Mine has broken plastic parts as well. I just duct tapped everything together until I get around to bypassing the valve. I don't think the bypass will hurt anything since that's how it's done on the 22re. The BVSV is designed to let gas fumes into the TB only after the engine reaches a certain temperature.
__________________
2005 Tacoma Access Cab TRD Off Road - A work in progress. |
| Tags |
| 22re, 4runner, 83, 94, bvsv, bypass, canister, charcoal, egr, evap, pickup, purpose, supra, toyota, tvv |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| BVSV (Bimetallic Vacuum Switching Valve) | Ebin | 86-95 Trucks & 4Runners | 2 | 01-26-2007 01:13 AM |
| Most Important upgrade | Thrillbilly | Offroad Tech | 9 | 08-21-2005 01:49 PM |
| Broken BVSV | ttr125mar | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 12-03-2004 07:17 AM |
| BVSV, is this the problem | ttr125mar | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 11-16-2004 06:53 PM |
| Need Help! Can I Bypass the BVSV of a VAN LE 4YEC? | Alfredo Nieto | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 09-30-2004 10:28 AM |
