Sign in using an external account
| Maintenance & Repair Archives Note: This section will be merged in with the other tech areas soon, and is now closed |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Guest
Personal
Sales Rating: (0)
How do you take the crank pulley off?
#2 (permalink) |
Personal
Sales Rating: (2)
crank pulley
to get the pulley off your were doing it rite by trying to get the big nut off. they usually are really tight you need to get a real long 1/2 inch breaker to get it loose even then it can still be a pain
__________________
jason liskey-----85 sr5 toyota 4runner 22re 5 speed 5" lift 33 " tires. for a trail rig 89 sr5 short bed 22re 5 speed for a daily driver 86 toyota dually 22re ex camper now a flat bed for a parts hauler/tow rig. soon to be a 5 speed |
#3 (permalink) |
Guest
Personal
Sales Rating: (0)
[OP]
Ok, so I got that off. What about the cam pulleys? I broke 2 wrenches, 1 socket, 1 ratcet, and a partrage in a pear tree. No, but seriously, I can't get those off at all. I used a 4 FOOT breaker bar!!!:cry:
#4 (permalink) |
Vendor
Sales Rating: (0)
I hope you are using Craftsman tools or some other brand with a lifetime guarantee.
Over on pirate 4x4.com I read that the easiest way is to set up a breaker bar against the left framerail and blip the starter to start the nut off. Edit: I have no idea about the cam pulley nuts, sorry. |
#5 (permalink) |
Personal
Sales Rating: (0)
Staff
VERY CAREFULLY!
Sorry I could'nt resist
#6 (permalink) |
Personal
Sales Rating: (0)
You can put a breaker bar against the frame rail and blip the starter. Works like a charm. Just make sure the ignition is disabled. Remove the coil wire or something.
__________________
-Glenn- |
#7 (permalink) |
Personal
Sales Rating: (0)
Oly884--How'd you end up doing it? I think I'm in a similar predicament.
Did you do the blip starter thing?Have fun all. DH6twinotter |
#8 (permalink) |
Personal
Sales Rating: (0)
Maybe the reply is a bit late but here is the solution for your problem with those sticky camshaft bolts. You'll have to use a paint stripper and heat the bolt the first time you'll remove the bolts. Or just use a lot of force.
Toyota uses Loctite on those bolts and this glues secures them to the crank or camshaft. Once removed you'll see a red or green material aplied to the bolts. This stuff is heat proof up to just above the boiling temp of water. So heat m up but replace your seals incase you overdid it. |
#9 (permalink) |
Guest
Personal
Sales Rating: (0)
[OP]
Well I got it off a long time ago, but I ended up sticking a wrench in the lobes on the cam and then proping it up on the side of the head, and broke a nice chunck off of the head, didn't matter though, I had a new engine. I did how ever heat it up untill it was glowing red and then spray it with wd-40
| Tags |
| 2000, 22re, 30, blip, cam, contour, crank, crankcase, crankshaft, easiest, engine, nut, pulley, starter, taking, toyota, wd |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| crank pulley???? | bunky | Newbie Tech Section | 2 | 05-16-2007 09:30 AM |
| 3.0 crank pulley | Mudcat | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 08-22-2005 07:54 PM |
| crank pulley tool | Ishinc | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 03-04-2005 11:45 PM |
| crank pulley | 884runner | 95.5-2004 Tacomas & 96-2002 4Runners | 19 | 10-02-2003 10:06 AM |
