How do I know if cv axle is good/bad? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 04-22-2005, 07:38 PM   #1
Dekri's Avatar
Im gonna be going out to the junkyard tomorrow to look for a cv axle and I was wondering how to tell if it's a good or bad cv axle. Like how to I check to see if the boot and joint are in good condition?
Pictures would help me out if you have any.
Dekri is offline
Old 04-22-2005, 07:40 PM   #2
green91runner's Avatar
well, if the boot is torn then, steer away from it.. if the boots are in good shape, grab the axle and try to move it back and forth, the less play in it the better, easier to tell when you get the axle out, then you can try 'compressing it', a good axle will compress less then a worn out one. thats the only things i can think of. as for pictures, unless the boots are off, you wont be able to see any of the worn out parts.
good luck
green91runner is offline
Old 04-22-2005, 09:03 PM   #3
Dekri's Avatar
thanks, I doubt I will find anything good there. Past two times I went there, there weren't any 4runners or tacomas, even if there are any, they're way to smashed up to pull anything off of em. People need to stop fixing up their wrecked runners so I can get the parts I want, lol.
Dekri is offline
Old 04-22-2005, 09:08 PM   #4
lol, i say the same thing.. theres maybe 4 2nd-gen runners that see the scrapyards here a year, and they're pretty totalled... and by the time i get to them usually half of the vehicle is scavanged.
Distance vertically between oil pan and highest part of axle housing? live4soccer7 84-85 Trucks & 4Runners 3 05-11-2016 07:52 PM
Newb looking to do an ENTIRE drivetrain conversion on 2gen 4Runner TheBFA Solid Axle Swaps, All Years 6 10-01-2015 01:18 AM
BLAZELAND LT IN 87 4RUNNER INSTALLED / CV comment and Question. JookUpVandetti 86-95 Trucks & 4Runners 10 09-30-2015 09:58 AM
Need 6 lug on a 2WD rear axle - only option to swap axles? Cycles 86-95 Trucks & 4Runners 8 09-29-2015 07:37 AM
86 Narrowed tons and 4Ds Toys4parts 86-95 Trucks & 4Runners (Build-Up Section) 2 09-26-2015 02:56 PM
Tags
axel, axle, axles, bad, boots, check, cv, determine, good, joint, joints, replaced, symptoms, tacoma, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
