| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
How bad was this clutch?
__________________
-Andy 99 4runner 5speed Lift: 3" revtek & 2" body; swaybar discos; diff drop Performance: TRD s/c & 7th injector kit, deckplate closed, elbow removed, TMC 1.1, lock-rite in rear Protection: tjm15 w/ tabor 9k, custom sliders Shoes: 305/70/16 nitto terra graps on 16x8 helo maxx 6's Stuff: lots of lights on the surco, yakima big powderhound right now, shackle hangers, sony head unit, aux fuse box, full time power outlets, seat covers, and home of the herculiner mod |
#2 (permalink) |
how many miles did you get out of it?
__________________
TOYOTA|moving forward 1996 3.4 Litre | 4-Wheel Drive | 5-speed Manual Transmission | Magnaflow Exhaust Deckplate | Intake Silencer Removal *MasterDebater*
#3 (permalink) |
If there is a way you can put up a picture of the clutch disk (on the left) at an angle, it would be helpful (close up). Initially, the clutch disk (on the left) in the first picture appears to have a significant amount of wear and heat damage for 5K miles (I think 5K miles is what you said earlier). Also, the backside of the pressure plate appears to have heat damage too. The big question is: Why was the clutch slipping?
Do you ever drive around with your left foot resting on the clutch pedal?
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#4 (permalink) |
A picture from the side would be more helpful. We need to see the edge of the disk some more. How much longer...anything would be a guess. I think you said 5th was slipping. It would only be a matter of time before 4th, then 3rd, then you couldn'r really do much without slipping all the time.
__________________
-Glenn- |
#5 (permalink) |
Yup, a picture like this would be nice:
__________________
Milton 01 Tacoma access cab 4x4 TRD TC Long travel, Supercharged 04 Tacoma Doublecab 4x4 TRD hoes all around! |
#6 (permalink) |
hope these are better. it was slipping pretty bad in 2nd through 5th. the clutch had approx. 5k on it. the way it was slipping....when i would be cruising at about 2k on the tach, and then floor it, the rpms would shoot up with no resistance.
__________________
#7 (permalink) |
that thing's wasted! you can see where it's wearing off the rivets!
when i pulled my old engine out, there were fragments of a previous clutch in the "pocket" between the engine plate and the block. looked like somebody tried to sidestep it at 5000RPMs.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#8 (permalink) |
5k miles? What was the problem?
__________________
#9 (permalink) |
I swear by my centerforce D/F clutch. But I think it may of been adding a new heavier flywheel at the same time. I got 8 years on this setup, and still going turning 33's. I used to go thru clutches yearly.
And yes , the pics of the shiney rivet heads means it was toast. Just like brake shoes.
__________________
Gregg 86 yota extra cab, 4" Pro comp, 33's, cam, header,CF Dual friction, K&N, and so on... (SOLD) 89 toyota 4x4 flatbed MY TRUCK |
#10 (permalink) |
glad to hear that! im wondering why it gave out so early. at least i got a new centerforce d/f in just in time.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| bad clutch bearing? | KegKiller | Newbie Tech Section | 2 | 06-23-2007 09:03 AM |
| Clutch install gone bad? | t3yfg5 | 86-95 Trucks & 4Runners | 2 | 07-12-2006 03:56 AM |
| Bad Valve Bad clutch Is it easier to pull engine? | jjenks0 | 86-95 Trucks & 4Runners | 10 | 03-01-2006 12:45 PM |
| Bad clutch or did it get hot?? | Lunnzz | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 11-01-2005 09:55 PM |
| Should a clutch smell this bad? | NMcruser | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 10-17-2004 03:28 AM |
