Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Headgasket update.
well... they have the block apart... it was the head gasket... so they're fixing that.
also they are doing a valve job, they said that some of the valves weren't closing all the way and were starting to burn and warp... so that's gonna add and extra $400 to the job.... so I'm going to be without the 4runner for like 2 weeks total, and out a butt load of money...... :cry:
__________________
'94 4runner : soon-ish to be V8'd, SAS'd, lock'd and bumper'd |
| Sponsored Links |
#2 (permalink) |
an extra $400 for a valave job? you are getting shafted?! i had my 22r head machined down, cleaned, pressure tested, all the valve seals replaced and a valve job done for $180
#3 (permalink) |
Yeah, $400 for a valve job? I think you're getting forked. Sorry to hear about the HG, too. At least it's not something worse, I guess.
__________________
'07 Tacoma Double Cab V6 4WD |
#4 (permalink) | |
Quote:
__________________
#5 (permalink) |
22r/re is alot different that a 3vze head. More valves to replace in the v6, more of a PITA to work on, harder to adjust vavles, etc. A friend of mine just had his heads rebuild and it costed him about $400 for a reputable machine shop.
I know how much it sucks to have your truck crap out on ya, today I think i found out my truck has a burnt valve. How much is the whole thing gonna cost you?
__________________
92 pickup... sold 90 integra- b18b turbo, intercooled, 10 lbs of boost, 240 whp... blown up 79 2wd yota pickup |
#6 (permalink) |
I don't even really know what the cost is at this point... it was $1100 for the headgasket, and that $1100 was assuming I didn't need to replace any other engine components... and now $350-400 for the valve job... so $1450 if i'm hella lucky... but it will most likely be like 1600 or so...
__________________
#7 (permalink) |
1100 for the head gasket and they werent going to do any of the head work?! dang... i sepnt $400 on my 22r, and i got a whole factory toyota gasket kit, had the machine work done and did the work myself... i know its a v6... but it still seems like he is getting shafted...... thats 4 times the cost and mine was only half the amount of work....
#8 (permalink) |
If you haven't already, you might want them to replace the waterpump, timing belt and idler pully thingy.
Since you're throwing around money as it is... Welcome to the wonderful world of the 3.0.
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! |
#9 (permalink) | |
Quote:
next time this thing craps out I'm swapping the engine.
__________________
#10 (permalink) |
Folks, you are all comparing two different machines.
A 22R/22RE is nothing like a 3VZ-E. Four hundred bones for a valve job does sound reasonable to me. I have been quoted seven hundred bones for valve adjustment. It is a time consuming and delicate job. |
#11 (permalink) |
doesn't the 3VZE use lifters and shims to adjust the valves? ugh...
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#12 (permalink) | |
Quote:
Finally someone realizes.....
__________________
#13 (permalink) |
This is the path I could have gone down. All that money......and it's still the 3.slow.
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#14 (permalink) | |
Quote:
__________________
#15 (permalink) |
why cant you buy a new head with all new valves etc from engnbldr.com????? wouldnt it cost about the same?
__________________
07 4runner 4.7 SR5 98 4runner 3.4 SR5 87 FJ60 |
#16 (permalink) | |
Quote:
__________________
3vze, 4x4, sr5, 90, auto, LSD 2x dB Drag World Finalist 2003 Nopi Nat. Street B champ 2004 SBN Street C champ 2004 SBN Advncd NW Champ 2004 Former WR Holder in NW. SPL: 159.8db @ 42hz In loving memory of Jamie Riggs 5/15/85 - 10/8/04 |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| please tell me its something other than my headgasket.... | kpaxfaq | 86-95 Trucks & 4Runners | 10 | 09-05-2006 09:01 PM |
| Ok so its NOT the headgasket... | rpeAMP | 86-95 Trucks & 4Runners | 13 | 02-21-2006 07:46 AM |
| Anyway to check headgasket? | ck-scooby | 86-95 Trucks & 4Runners | 14 | 01-12-2006 03:46 PM |
| best headgasket? | runnerboy97 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 09-30-2004 10:01 PM |
| headgasket | TRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 07-25-2003 02:23 PM |
