| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Going to get wheel seals done at the dealer...
#2 (permalink) |
expect one good thing...you wont have to carry a wallet anymore cause you wont have anyhting to put in it....
__________________
98 taco, 4x4, TRD, SR5, extended cab, v6. 3" on 32s (dd) 86 4runner 5spd SAS soon to be geared and locked! (CRAWLER) 2000 yamaha superjet setup for freestyle, cause thats just how i roll! |
#3 (permalink) |
You mean the axle seals and rear brake job? Both axle seals are bad?
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#4 (permalink) |
Both seals blew. And, apparently, fluids make the shoes swell up, so were going to have that replaced too.
#5 (permalink) |
Were you off roading and have not done a breather mod?
__________________
Traded in: 2005 Tacoma DC PreRunner SJ Package Silver Streak Mica Traded in: 2007 Camry LE Silver |
#6 (permalink) |
Unfortunately, yes. I ordered the parts to to the mod though, theyre coming in Wed, Ill install them then. The surgery appointment is Thursday.
#7 (permalink) |
savings? what savings?
#8 (permalink) | |
I think I paid $400 in change for both inner and outer axle seals on both sides and new shoes
It is expensive
__________________
Eric 88 4runner Quote:
#9 (permalink) |
I'm having my rear seals done and I'm also getting front and rear shocks and coils installed and the damage including new rear shoes is under $700 from the Mitsubishi garage that sponsored me when I had my Eclipse. I'm sure the seals are solidly under $500.
__________________
'99 4Runner Highlander 4wd E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub |
#10 (permalink) |
Both inner and outer seals replaced here on both passenger and driver side, brake pads and machining the drums ran around 500. Call it a moment of weakness on the brake job, instead of doing it myself.
Not sure if the following is good or bad. Maybe both. Two weaks later the driver side was leaking again. (of course that's bad) The upside was the shop replaced the seal and once again replaced the brake pads (though I think this time they just wiped out the drum) without so much as asking for cash. Not bad for a stealership. (they shouldn't have asked, but its a stealer)
__________________
Ben - 97 sr5 - full of win. |
#11 (permalink) | ||
Quote:
__________________
#12 (permalink) |
Inner and Outer Axle seals, machining drums, new shoes, new fluid, and labor = $800 + Tax @ Toyota in Lancaster, MA.
#13 (permalink) |
I'm glad I did this myself. $5.99 for the seal and $19.99 for brake shoes sure beats $500-800. An afternoon job if you have the space and tools.
__________________
Todd 1994 4runner SR5 V-6 5 speed SDORI B/J Spacers FZJ 80 Coils/Rancho 5k's Pro Comp Panhard Drop Bracket JDM PIAA Lighting BFG MT's 33x10.50 2009 Toyota Yaris LB 2008 Honda Pilot EX-L 4wd 1996 Ducati 900SS CR |
#14 (permalink) | |
Quote:
__________________
2008 Mini Cooper |
#15 (permalink) | |
Quote:
#16 (permalink) | |
Quote:
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#17 (permalink) |
once again gangus, not even a kiss
__________________
89 SR5 p/u 3.0 5 speed, doa cams, downey headers, jacobs igniton, self made isr pipe, electric fan, 14"flowmaster, allpro rear spool, 63"chevys, 4crawler 2"bl, bj spacers, skymanufacturing u-bolt flip & shock tower, ranchos, 1 1/2 square tube bed, aisin hubs, 35x10.5x15 super swamper boggers.....For ever a work in progress 2000 Tundra SR5 V8 4x4 Bone stock DD/Tow Rig |
#18 (permalink) |
Replaced Rear Leaking Axle Seals Labor $240
2x O Rings $12.27 Each $24.54 Total 12 GLB PT Gear Lube $3.65 Each $43.80 Total 2x Oil Seals $12.87 Each $25.74 Total 1x Breather Plug $8.80 (Even though I asked them not to replace the breather since I was going to do the extension anyways) Rear Brake Service Labor $160 2x Brake Drums $113.79 Each $227.58 Total 1x Brake Cleaner $4.45 1x Rear Shoes Kit $73.13 Lube Disposal $10 Sales Tax $20.55 Grand Total $841.59 and 2 bottles of KY |
#19 (permalink) | ||
Quote:
__________________
#20 (permalink) |
doesn't help that they REPLACED the drums! that is where they got you. and the breather...why wouldn't they replace it? you told them not to, but how could they warranty the work when it was the breather that caused the problem in the first place?! i never would have let them do the work until i got a quote first. if you had done that, then you could have told them to turn down the old drums.
actually...did they even replace the drums? you should look to see. if they didn't, then the also jipped you on the 2 bottles of ky you think you got. |
#21 (permalink) |
Yes, I did check to see if the rear drums were replaced. Brand new (I checked for the cracks I put in it when I was trying to take them off)
Apparently, the rear drums were "so soaked in oil it was impossible to machine them". When I brought the truck in they said they were going to look over the truck to see exactly why it was leaking, then call me with the quote. When they called with the $800+ tax quote, I told them I was going to take the truck home and find money for the repair, adn thats when they told me about the $80/hour diagnostics fee, and that they spent 3 hours finding the leak. Last edited by Gangus2006; 10-29-2005 at 01:54 PM. |
#22 (permalink) |
that is insane! why would you ever do that?! you knew it was the seals
you should really listen sometimes. could have saved some $$$$$. but that is all said and done now. glad the runner is fixed. |
#23 (permalink) |
you sir have been
__________________
#24 (permalink) |
I got OEM rear brake pads for under $30 and the OEM seals only ran me $7/each. I also had to replace the brake cylinders in the rears and that added about another $80 to the bill for the pair.
The dealerships just rape you since a solid reputable independent garage would have saved a person at least a couple hundred bucks.
__________________
#25 (permalink) | |
Quote:
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Injector seals | cweich | 86-95 Trucks & 4Runners | 5 | 07-09-2007 10:27 AM |
| 1998 4runner rear wheel bearings/seals... | poser | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 11-14-2006 12:17 PM |
| Put seals in steering gear how much play in steering wheel | jjenks0 | 86-95 Trucks & 4Runners | 3 | 06-12-2006 06:13 AM |
| Oil filters at local Yota dealer/national dealer rankings | Silver_Truck | Off Topic Talk | 1 | 07-10-2005 12:03 PM |
| Dealer License, Dealer auctions | shazaam | Off Topic Talk | 17 | 12-16-2004 04:05 PM |
