front end clunk when first stopping after change of direction - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-10-2005, 12:16 PM   #1 (permalink)
bflooks's Avatar
hey guys. 98 4runner, 16" wheels, 5 spd., 4x4, 3rz.
i changed out front pads about 2 months ago. shortly after, i started getting a clunk/bang in the front end that you can feel through the brake pedal and under your feet when first stopping after changing direction.
i looked at the brakes, and all is in order. i just changed the sway bar bushings and an end link i snapped because they were in tough shape. i still have the sound.
here is the question:
last year i had a calliper replaced. when i changed out the pads this past time, i put in performance friction pads, but the passenger side did NOT have the shims behind the pads. could this cause a shift/bind in the pads that in turn would cause a clunk when they reseat?
okay...should i mention that it is not the ball joints? those were checked by a garage. all is tight.
bflooks is offline
Old 11-13-2005, 04:49 PM   #2 (permalink)
bflooks's Avatar
just thought that i would post up and say that i have tracked it down to the peformance friction pads.
replaced them with the $15 valuecraft pads for trouble shooting purposes, and sure enough...the pf pads were actually on a smaller backing plate than the new ones. there is NO sounds or feelings anywhere with these new pads. i am off to return the pf pads and looks like i will be doing front brakes once a year (warranty).
bflooks is offline
Old 11-13-2005, 09:41 PM   #3 (permalink)
DoubleZero4x4's Avatar
Interseting post...I have had the same noise recently. It seems to be related to my brakes too but I am going to be doing the Tundra brake upgrade so I will see if that resolves the issue.
__________________
2000 4Runner SR5 4x4 Sport
Mods: Crimestopper Remote Start Alarm - Deck Plate Mod - 400W Inverter - Limo Tint - K&N Air Filter - Tundra Brakes/w Ceramic Pads & PowerSlot Rotors - Hayden Trans Cooler - Goodridge SS Brake Lines
2000 4Runner LTD 4x4 - Wife's
Mods: Deck Plate Mod - Tundra Brakes/w Ceramic Pads & PowerSlot Rotors - Goodridge SS Brake Lines - 400W Inverter
DoubleZero4x4 is offline
Old 11-14-2005, 12:21 PM   #4 (permalink)
Send a message via AIM to 2000t4r
I have a similar problem and Toyota informed me that it is brake shift. I believe that it is the shims that are moving back in forth. Did you happen to put the glue stuff back on the shims when the pads were replaced?
2000t4r is offline
Old 11-14-2005, 03:43 PM   #5 (permalink)
bflooks's Avatar
the glue stuff? if you are referring to the brake grease, then yes. i did.
as i said, i am not sure if the original autozone i bought the pf pads from gave me the wrong ones or not, but... the new ones i have fixed the issue. what that means....???? i just know that the pf pads were the cause of the noise and pop in the pedal.
bflooks is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
clunk, clunk, clunk noise from front left wheel in 79 4x4 .faded.fedor. General Vehicle Related Topics (Non Year Related) 2 04-02-2007 09:14 AM
front end *clunk* Rocklobster 86-95 Trucks & 4Runners 11 04-13-2006 06:41 PM
A change in direction? Flygtenstein Off Topic Talk 37 02-27-2006 01:15 AM
Front End Clunk Noise Grimace 95.5-2004 Tacomas & 96-2002 4Runners 7 06-04-2003 11:31 PM
2009 InternetBrands, Inc.
