| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
flywheel torque, and clutch face direction on 3.slow
__________________
Karl Kraus --Education is a crutch with which the foolish attack the wise to prove that they are not idiots. Last edited by Eric; 04-08-2005 at 07:16 PM. |
#2 (permalink) |
If you are talking about the hooking the flywheel to the crankshaft I know a 22re is 80 FT/LBS. Not sure about a 3.0 but I would imagine it to be the same. Not sure about the other question. Sorry. http://personal.utulsa.edu/%7Enathan...fsm/index.html Try that fsm.
__________________
YOU GOTTA GET A LITTLE MUD ON THE TIRES |
#3 (permalink) |
On the clutch disc the flat side toward the flywheel and the torque for flywheel bolts are 65 ft lbs, pressure plate bolts are 14 ft lbs!!!
__________________
94 Toyota P/U Ex-Cab 3.0 Automatic 4X4 |
#4 (permalink) |
that manual is great!
torque is 65fl/lbs clutch disc is installed as option "b" thanks for your help!
__________________
Karl Kraus --Education is a crutch with which the foolish attack the wise to prove that they are not idiots. Last edited by Eric; 04-11-2005 at 06:17 PM. |
| Tags |
| 30, 87, clutch, direction, disc, disk, face, flywheel, go, plate, pressure, slow, torque, toyota, v6 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Help connecting the flywheel to the torque converter | hellonweels89 | 03+ 4Runner/GX470, & 05+ Tacomas | 7 | 10-19-2006 11:38 AM |
| Installed a new flywheel and clutch | AH64ID | 86-95 Trucks & 4Runners | 3 | 07-30-2006 05:18 AM |
| MAF on 3rd Gen : which direction does it face!? | 98LimitedCustomized | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 10-31-2005 05:12 AM |
| 22re flywheel torque specs? | Dr.Feelgood | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 09-11-2005 10:05 PM |
| Lining up torque converter with flywheel for bolt install | naksukow | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 08-11-2005 09:28 PM |
