Engine problems
Old Apr 25, 2005 | 08:54 AM
Praufet's Avatar
Engine problems
So after my radiator blew, I am starting to notice some odd engine behavior. The oil pressure seems to be low, the temp gauges wanders from normal position to almost redline, a rattle comes from the engine when I rev it and then let off. Any ideas? Do I need a new engine?
Old Apr 25, 2005 | 10:03 AM
Praufet's Avatar
The idle also changes at almost every stoplight, ranging from 1-2k rpms
Old Apr 25, 2005 | 02:10 PM
Praufet's Avatar
Anyone?
Old Apr 27, 2005 | 12:15 PM
Tiger Paw's Avatar
Did you purge the air from the system when you replaced the radiator? There's a thread somewhere on the board about it. As for the rattling, may be the timing chain. Not sure if your year has the chain or belt. Good luck!
Old Apr 27, 2005 | 12:46 PM
My99's Avatar
why did the radiator "blow"? How hot did the truck get when this happened?
Old Apr 27, 2005 | 05:10 PM
Praufet's Avatar
There was a leak. I used some repair stuff, it seemed to be working then while driving I see it start to smoke, pull over, pop the hood and coolant is all over the engine bay.
Old Apr 27, 2005 | 07:33 PM
My99's Avatar
So the engine never overheated?
Old Apr 27, 2005 | 08:13 PM
Praufet's Avatar
didn't seem too. With out any coolant, the temp sender could give an accurate reading, but the temp never went into the red.
Old Apr 30, 2005 | 11:07 AM
Blair's Avatar
"Hunting" for an idle speed and a wandering temp. gauge are a good indication of an air bubble in the system. Give it a good burping.
Rattling sounds coming off of a speed run could suggest a loose heat shield. Seeing that the engine did NOT overheat check the simple stuff, first.
steve miller
Oct 10, 2015 01:40 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
