engine belt/timing belt replacement question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-10-2005, 07:50 PM   #1 (permalink)
Send a message via AIM to gomezza
Hello all,
I've beeen doing a lot of searching about changing the belts in my 99 4runner. I would love to save money by doing it all myself but wanted to know how hard it is?? Do I have to worry about messing up the timing? Anyone willing to Scan directions from a toyota repair man on how to do this i have a 99 3.4 sr5. I read its a good time to do the water pump as well. Any scans/pictures/help would be awesome!! Thansk guy!
H-
__________________
99 4runner SR5 3.4L, Infinity Sub/speakers, Alpine sattlite radio, brush guards. Just installed remote start-- I'm proud of myself..yay!!
gomezza is offline
Old 04-11-2005, 06:14 AM   #2 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
From this link:
http://yotatech.com/showthread.php?t...ht=timing+belt
....you would find these:
http://www.toy4x4.net/timing_belt/index.htm
http://www.lieblweb.com/tacoma/Mecha...cans/index.htm
Hope it helps.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 04-11-2005, 03:48 PM   #3 (permalink)
I just did mine and it wasn't that bad, but it does take several hours to do if you are doing it by yourself and are changing the water pump too. You also need to figure out how to loosen the cranshaft pulley bolt, ie. impact gun or using a breaker bar resting against the frame rail and using the starter to break the bolt loose. I would say if your dealer has a special going for $250 or less, let them do it. I got a coupon for $209, but I decided to do it myself. I also changed out all the other belts, waterpump and thermostat as well. Also, I bought a special tool from Snap On to compress the tensioner so you can get the new belt on without removing the tensioner itself. Part #YA9370, if memory serves me right. It's about $60. You can get a waterpump online from 1sttoyotaparts.com for right around $100 delivered, it does not come with a thermostat so order that as well. The whole thing really depends on how much you value your time and if you feel comfortable tackling a job like this. I would say you need at least moderate mechanical ability. You can mess up the timing, but you will want to double check your timing marks on the crank pully and the cam shafts before you button everything up. According to the dealer, the 5VZFE is a non interference engine so the valves will not hit the top of the pistons if your timing is off, so at least you won't hurt the engine.
ACPlayer is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
real time timing belt replacement question poriomaniac 95.5-2004 Tacomas & 96-2002 4Runners 4 09-06-2005 06:53 PM
Timing Belt Replacement jm47 Maintenance & Repair Archives 3 04-05-2005 11:53 PM
Timing belt replacement callmej75 95.5-2004 Tacomas & 96-2002 4Runners 24 02-01-2005 08:03 PM
Timing belt replacement CLin9383 95.5-2004 Tacomas & 96-2002 4Runners 6 11-01-2003 03:08 PM
2009 InternetBrands, Inc.
