| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Door lock
#3 (permalink) |
You'll have to take it apart and look at it. Maybe one of the linkages has popped loose.
For me, the hardest part of removing the door panel the first time was the door handle. Remove the screw, push the whole handle forward about 1/4", then it'll come out. Unhook the clip on the linkage, and it's off. The rest is pretty easy to figure out. You'll have to remove the plastic covering behind the door panel also, then get a light and look up the the inside of the door handle when turning the outside lock. If you don't see anything obvious, you can always take apart the passenger side and make comparisons. Let us know what you find.
__________________
Rob 95 Runner SR5 V6 5sp ATK engine, K&N FIPK, NWOR headers, high-flow cat w/2.25" Dynomax Super Turbo, 15X8 Centerlines, Michelin 32X11.5, Aisin hubs, Factory Brush bar, PP Rear Springs, KYB Monomax shocks, Westin Nerfs, Bushwackers, Weatherflectors, OME Steering Stabilizer, Marlin Short Shifter, White gauges, Taurus fan, MR2 100 Amp alternator, stereo&alarm w/DEI 530T 4:88's w/Supra LSD Front and Rear |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Power door lock | Neaners | 86-95 Trucks & 4Runners | 0 | 11-03-2006 11:20 PM |
| Door Lock Help!! | bigacuralvr | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 08-07-2006 09:48 PM |
| Door lock Problem | cimahar | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 12-25-2005 05:04 PM |
| Remote Door Lock | Gentleman | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 10-09-2003 05:40 AM |
