Crank pulley hell - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-14-2005, 09:52 PM   #1 (permalink)
vegaskurt's Avatar
Crank pulley hell
Doing the timing belt and water pump and ran into a snag....
Got the crank pulley bolt off without any problems but I cant get the pulley its self off. So I tried a cheap 3 jaw puller and ended up chipping a small piece of pulley off in the process..
So now the pulley is still on the crank and now I need to replace the pulley. Any tricks to getting this thing off?
vegaskurt is offline
Old 11-14-2005, 11:13 PM   #2 (permalink)
4Crawler's Avatar
Not sure on the V6, but I picked up an inexpensive puller at a local tool store that worked perfect on my 22RE pulley:
http://www.4crawler.com/4x4/CheapTri...l#CylinderHead
I just made sure the puller came with some metric bolts, M8-1.25 fit the threaded holes in the crank pulley perfectly.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 11-14-2005, 11:18 PM   #3 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
hmmmm..... i jsut pulled on mien when i did the timing chain on my 22r, after the bolt was out i was able to jsut pull it off..... my ogre strength might have something to do with that though....
jimbo74 is offline
Old 11-14-2005, 11:27 PM   #4 (permalink)
4Crawler's Avatar
Mine pulled off easy the 2nd time I had it off, but the first time it was somewhat tight, puller came in handy.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 11-15-2005, 07:10 AM   #5 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
both times ive had to take a pullly off of a 3vze ive had to use my puller. I put the crank bolt back in (leaving it a 1/4" loose or so) put the puller on the BACK of the pulley and start cranking down on it. (i have a 3 jaw) crank down on it till it gets hard to turn then take a dead blow or rubber mallet and beat on the pully, then crank on the puller some more and repeat. After the pulley has moved some, youlll have to back the crank bolt out some more and repeat.
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 11-15-2005, 07:22 AM   #6 (permalink)
4Hummer's Avatar
Mine just popped off with a couple whacks of the hammer.
__________________
Michael
1991 4Runner 22RE.
CHOP
www.obsessiveoffroadclub.com
4Hummer is offline
Old 11-15-2005, 09:34 AM   #7 (permalink)
vegaskurt's Avatar
Well here is a pic of the damage. A new crank pulley from toyota is about $400 but I found one at a local import salvage yard for much much less. Guess the OME coils will have to wait another few weeks. Now to find a puller tool.
Old 11-15-2005, 09:44 AM   #8 (permalink)
tc
tc's Avatar
I just used a puller threaded into the two holes in it (I think that's one in the bottom of the picture). Came off quite easy...
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 11-16-2005, 08:38 PM   #9 (permalink)
DH6twinotter's Avatar
Quote:
That sounds like the same one I used. 2 long bolts that went into the holes where the PS pulley goes on and then a big bolt in the middle that screws in how Snap-on described. I got it using AutoZone's loan a tool program.
1st time, it was stuck on really tight. I thought I busted something when it finally came loose. 2nd time I did my timing belt, I didn't have to use anything.
Just my $.02.
__________________
1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto.
15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick
Planned stuff: Pre-runner light bar with Hella 500s, small lift
Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow.
DH6twinotter is offline
Old 11-17-2005, 08:47 AM   #10 (permalink)
leiniesred's Avatar
hmm. Use a piece of flat bar stock and drill 2 holes in it the same spacing as the 2 holes in the pully. hit it with the PB blaster too.
Have a bunch of washers handy or be ready to cut the bolts off because they can't be too long or they hit stuff behind the pully.
Now, find a socket that fits well between the pully bolt and the plate you screwed on there. Starting to make sense? Unscrew the crank bolt jamming the socket against the bar stock. keep going. Add some more spacers if you run out of crank bolt thread.
You will force the pully right off from the INSIDE. You COULD try to crank it off by tightening the 2 bolts against the crank bolt, but it is possible to strip the threads in the pully and then you are really stuck. besides it means a lot of screwing/unscrewing as you have to keep adding washers/spacers behind the bolts.
TAP it with a hammer too. The virbation really helps. Remember to tap INSIDE the pully where the rubber damper won't absorb the shock. use a 3/8ths extension to get in there.
__________________
yeah.
leiniesred is offline
Old 11-17-2005, 11:01 AM   #11 (permalink)
vegaskurt's Avatar
Finally got it off. I bought the universal puller kit from harbor freight for $10 and it came with some M8 1.25 bolts. Cranked, cranked and cranked and it finally came off. The shaft looked a bit discolored, looks like water from the bad pump got moisture in there and probably rusted the shaft to the pulley.
Tags
2003, 22r, 22re, bolt, chevy, crank, crankshaft, deadblow, impala, puller, pulley, pully, toyota, unscrew, wobble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
crank pulley???? bunky Newbie Tech Section 2 05-16-2007 10:30 AM
Crank pulley wobble? bmwpower 95.5-2004 Tacomas & 96-2002 4Runners 21 06-28-2006 01:18 PM
3.0 crank pulley Mudcat 95.5-2004 Tacomas & 96-2002 4Runners 2 08-22-2005 08:54 PM
crank pulley 884runner 95.5-2004 Tacomas & 96-2002 4Runners 19 10-02-2003 11:06 AM
How do you take the crank pulley off? oly884 Maintenance & Repair Archives 8 05-10-2003 09:44 PM
2009 InternetBrands, Inc.
