| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Cracked Head or Blown Head Gasket?
#2 (permalink) |
By the way, I was loosing coolant really bad, now I know why. The truck actually still runs, but I'm not driving it cause I'm skeered I'll pop that piston when that valve decides to stick, and because of my luck it would
![]() -Steven |
#3 (permalink) |
just curious, which plug was carboned up? #3 and #4(or both) are really common for the head gasket to blow on.
if you're overheating, that could be a reason for your problems. 9 times out of 10, overheating will kill a head gasket or crack a block or head. the other 1 time, it's due to a poor gasket surface or damaged gasket. i blew my head gasket last wednesday, but got lucky since it was only blowing exhaust through the coolant. pulled all the plugs and they looked good, except for #4 -- lots of carbon gunk. ended up the fire ring looked like it had hit an irregularity in the head and expanded out into the cylinder, and it had cracked.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#4 (permalink) | |||
Quote:
Quote:
Quote:
What's your prognosis? New head? -Steven |
#5 (permalink) |
i just took it into the machine shop to get it cleaned up, mainly for peace of mind. i had the block milled when i rebuilt the engine, but never touched the head(other than replacing valve stem seals).
if it blows again i'm going to probably build a late 22R engine. hopefully it won't come to that though
__________________
#6 (permalink) |
After talking with a guy from engnbldr.com he pretty much assured me that all my problem stems from a blown head gasket and he seriously doubts that I've cracked the head or done any serious damage. Apparently pretty common with 100k + 22r engines. I guess I'll know more once the head is out and taken to the machine shop. I'm also going to upgrade my cam while we're in there.
-Steven |
| Tags |
| 3rz, 4runner, 98, block, blown, crack, cracked, difference, engine, exhaust, gasket, head, overheating, tacoma, v6, vs |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Difference between a cracked head and a blown HG | WillRadford | 86-95 Trucks & 4Runners | 12 | 04-05-2007 04:21 PM |
| Blown head gasket? | raymeg | 84-85 Trucks & 4Runners | 0 | 03-16-2007 01:12 PM |
| Blown Head Gasket | bigpest88 | 86-95 Trucks & 4Runners | 12 | 04-26-2006 04:40 PM |
| Blown Head Gasket Blown! '95 3.0...Looking for advice... | bgibb | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 06-12-2005 02:52 PM |
