| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Maintenance and lifting questions for 94 Toy truck, 2wd, 4 cyl...
#2 (permalink) |
3 words for you...FSM
Factory Service Manual. Belts: Get OEM belts, there are internet wholesalers who sell genuine Toyota parts for a pretty good deal. They are really easy to replace yourself. Coolant: The FSM will tell you every step. You will need a 5 gallon bucket, and some patience. Kind of a pain really. Disposing of the old coolant sucks, so its almost worth someone else doing it. Have you done plugs and the cap and rotor? Towing: You can add a leaf spring to each side of the rear, then crank up the torsion bars a little. More power: I/H/E Intake Header Exhaust. That will get you started.
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#3 (permalink) |
I just put in Kelly Springfield belts. I doubt Genuine Toyota belts could really be much better. Loosen the center nuts on the idler pulleys and loosen the adjuster nuts a lot till you can get the old belts off. On the alternator loosen the top nut and slide the alt. in toward the motor to get the belt off. Use belt dressing to give the belts better traction on the pulleys. To tighten the alt belt I wedged a piece of wood between the motor and alt. to get enought tension. After a few days it will need to be re tightened.
Turn the heater control all the way to hot. Open the drain cock on the radiator and drain it into a bucket as stated. Look at your hoses and replace if there is any doubt about their condition. If you are that far into it do the thermostat also, its cheap insurance. Use DISTILLED water to dilute the antifreeze. Anything else like tap water will corrode your cooling system and clog your heater core. Then you will be in trouble. I use a Haynes manual because I don't have the cash for an FSM. Sometimes FSMs are on e-bay pretty cheap though. Tune up with valve adjustment, grease the driveshaft and balljoints. At 90,000 or so you need to replace timing chain. With frequent oil changes and quality gas that motor will run forever. Bad gas will foul your oxygen sensor. Air helper springs. Pump them up when towing, deflate them some when not. They are pretty cheap also. A local competent welding and fab shop. Supra motor swap. Just kidding. Amsoil filter. 2.25" Catback exhaust.
| Tags |
| 02, belt, belts, chain, change, changing, clogging, colorado, cyl, dressing, replace, tacoma, timing, toyota, truck |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Tools needed for timing belt change | Pete | General Vehicle Related Topics (Non Year Related) | 7 | 06-16-2006 09:21 AM |
| Pending Timing Belt change - parts list needed | aowRS | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 08-11-2005 05:39 AM |
| Time to check/change your coolant? | Yoter | Maintenance & Repair Archives | 2 | 11-18-2004 03:34 AM |
| Am I reading this right? 100K mile coolant change, etc. | Pitbull | Maintenance & Repair Archives | 3 | 03-31-2004 08:09 AM |
| Just did my first oil change on my 03 Runner 6 cyl | Ant | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 09-19-2003 11:14 AM |
