| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
clutch squeak NOT BUSHING
#2 (permalink) |
Maybe it's your knee?.....jk
Have you tried spraying the mechanism down with a spray lubricant? |
#3 (permalink) | |
Quote:
![]() well i spread some grease on the components that connect the pedal to the fork thing...it worked for that day, but the next morning it was back again ...
#4 (permalink) |
Check the pedal assembly for any cracks and fluid leakage around the boot of the clutch MC. It's possible that the assembly itself is faulty or the clutch MC is letting air into the hydraulic systema and the piston in the cylinder has worn down.
Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD Last edited by YotaJunky; 11-23-2005 at 04:06 PM. |
#5 (permalink) |
Super Moderator-Sponsoring Member
Staff
WD40 on the spring connection to the pedal assembly...mine did that squeaking thing...and WD40 later no more squeak in a year.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
| Tags |
| 4runner, bushing, clutch, forum, hydraulic, mazda, mazda3, pedal, runner, spring, squeak, squeaky, squeel, toyota, yotatech |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Clutch goes squeak, squeak, squeak like a hamster wheel | SuaveGato | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 08-30-2006 04:02 PM |
| Clutch Squeak | pullnshoot25 | 86-95 Trucks & 4Runners | 11 | 03-21-2006 07:52 PM |
| cruise control not working...clutch bushing? | northfacer581 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 11-25-2005 03:12 PM |
| clutch bushing | SolidDigital | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 06-18-2004 08:52 PM |
