clutch bleeding problems
Old 07-02-2005, 10:42 AM
ohioyotaguy's Avatar
I just put a new clutch master cylinder and slave cylinder on my 88 yota truck, 3.0L, 5 speed, 4x4. Me and my mechanic bled everything and it was fine going home. But this morning I got in it to move it and the pedal was to the floor. Any ideas?? Pressure plate and throwout bearing are only 10K miles old. Any help is much appreciated. Thanks.
Jeff
ohioyotaguy is offline
Old 07-02-2005, 12:19 PM
seaflea's Avatar
sounds like you didnt get all of the air out of it and overnight it formed one big bubble in the line. Bleed it some more.
seaflea is offline
Old 07-02-2005, 05:22 PM
Greg'sToy's Avatar
a good old gravity bleed should help things out..
Greg'sToy is offline
Old 07-04-2005, 02:19 PM
sweet, got it fixed. Went to Autozone and bought a vacuum pump and got it bled TIGHT. Thanks for the replies.
the1998sr5
15
07-14-2020 08:35 PM
PlayAwhile
07-20-2015 11:36 AM
1996Taco
07-20-2015 12:02 AM
the1998sr5
07-16-2015 06:20 AM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: clutch bleeding problems
