CE Light - Any info/advice?
Old 02-11-2004, 10:47 AM
bbeast's Avatar
Well, I finally got to Autozone and checked the code on my CE light. Here's what came up......
PO441 - EVAP Emmissions Control
This light came on a little while after I did the ISR Mod. For the ISR Mod on my rig, I used heavy duty SCH 80 PVC End Caps and ribbon style hose clamps, so I'm pretty much positive I don't have the vacuum leaks that some experienced because of warped end caps.
Does anyone have any idea what might cause this CEL code? Is this something I should be worried about? Thanx,
Brad
bbeast is offline
Old 02-11-2004, 01:17 PM
MTL_4runner's Avatar
Did you reroute all the hoses to be stock per Christian's writeup?
https://www.yotatech.com/~corey/tech...r/96runner.htm
I doubt you have a leak too but a hose could be hooked up incorrectly also to cause that.
Did you pull the ECU fuse after to reset the code and it came back?
MTL_4runner is offline
Old 02-12-2004, 09:42 AM
bbeast's Avatar
MTL_4runner
Thanx for the response. However, I'm s/c'd so I only have one nipple installed in the large end cap for the power steering vacuum line. I only need this one as I am using Gadget's free-fmu Mod to maintain constant 50psi fuel pressure. I really have no idea what is causing this CE light, so any ideas would be appreciated........
bbeast is offline
Old 02-12-2004, 10:56 AM
See if this helps you at all with truobleshotting the problem.
http://www.troublecodes.net/articles..._Test_Kit.html
Old 02-12-2004, 11:15 AM
The full code is "P0441 EVAP Control System - Improper Purge Flow" This can be from something as stupid as a bad gas cap seal to others (gas cap / Evaporative purge solenoid / Clogged purge line / Vacuum hose / Evaporative emission canister clogged , etc). This link will explain alot for you:
http://www.autoshop101.com/forms/h62.pdf
I still think that if it came on right after you changed the vauum lines then the purge line is not hooked up correctly somehow.
Old 02-13-2004, 08:50 AM
bbeast's Avatar
MTL_4runner - thanx
Thanx for the response - very informative stuff. I guess I'll be checking all my vacuum lines this w/e - I can't see it really be that Purge port since I never had to mess with that. Damn is that light annoying though...... Take it easy,
Brad
bbeast is offline
Old 06-24-2005, 10:43 AM
BOSTON4RUNNER's Avatar
check out my posts/thread in the regular maint. forums
might be a help, i hope
BOSTON4RUNNER is offline
ashersullivan88yota
01-18-2022 05:37 PM
4.34runner88
08-11-2018 10:44 AM
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
Quick Reply: CE Light - Any info/advice?
